Lizenzfehler in Connector for UMS (msx2kgate0)
    ich bekomme immer den oben stehenden Fehler.
    Folgendes steht im Logfile:
    Opened on Wed Jul 27 17:55:10 2011
    Library version 4.0.2.24052
    (4276) 11/07/27 17:55:10 - DEBUG: Start: Open Registry hive.
    (4276) 11/07/27 17:55:10 - DEBUG: Start: HKCU Hive open.
    (4276) 11/07/27 17:55:10 - DEBUG: Start: Local Machine Hive open.
    (4276) 11/07/27 17:55:10 - INFO: CreateDefCfg(): Creating a default configuration unit.
    (4276) 11/07/27 17:55:10 - DEBUG: MakeDirs(): Creating ']CNV_MOUNT_CENTRAL[/work/msx2kgate0/in'.
    (4276) 11/07/27 17:55:10 - DEBUG: MakeDirs(): Creating ']CNV_MOUNT_CENTRAL[/work/msx2kgate0/out'.
    (4276) 11/07/27 17:55:10 - DEBUG: MakeDirs(): Creating 'C:\ProgramData\FFUMS\fmsrv/work/msx2kgate0/tmp'.
    (4276) 11/07/27 17:55:10 - DEBUG: MakeDirs(): Creating 'C:\ProgramData\FFUMS\fmsrv/work/msx2kgate0/metacache'.
    (4276) 11/07/27 17:55:10 - DEBUG: MakeDirs(): Creating 'C:\ProgramData\FFUMS\fmsrv/work/msx2kgate0/undeliverable'.
    (4276) 11/07/27 17:55:10 - DEBUG: MakeDirs(): Creating 'C:\ProgramData\FFUMS\fmsrv/work/msx2kgate0/error'.
    (4276) 11/07/27 17:55:10 - DEBUG: MakeDirs(): Path 'C:\ProgramData\FFUMS\fmsrv/data/stationery' opened.
    (4276) 11/07/27 17:55:10 - DEBUG: License Check: The license parameter 'Enable' for code '50' could not be read.
    (4276) 11/07/27 17:55:10 - DEBUG: License Check: The license parameter 'MajorVersion' for code '50' could not be read.
    (4276) 11/07/27 17:55:10 - DEBUG: License Check: The license parameter 'MinorVersion' for code '50' could not be read.
    (4276) 11/07/27 17:55:10 - ERROR: License Check: At least one service is not licensed anymore (Fax: 0, SMS: 0, Voice: 1).
    Closed on Wed Jul 27 17:55:14 2011
    Ist da das Lizenzfile defekt oder wo könnte ich noch nach dem Fehler suchen.
    Installiert ist OfficeMaster 4.0 Basislizenz
    Vielen Dank
    Lizenzfehler beim Starten der Komponente msx2kgate0
    die Meldung
    "License Check: At least one service is not licensed anymore (Fax: 0, SMS: 0, Voice: 1)"
    bedeutet, dass die Komponente msx2kgate0 vorhandene Lizenzflags der Lizenzdatei über den Server alloziert. D.h. er wird jeweils einen Service Fax, SMS und Voice für sich beanspruchen, um damit andere Komponenten zu blockieren, wenn die Lizenz dies nicht hergibt. Der Controller des Messaging Servers zählt jeweils die allozierten Komponentenzähler um eins zurück. Wenn nun Fax und SMS Null ist, bedeutet das, dass schon jemand diese Zähler belegt. In aller Regel sind das FileGWs oder MailGWs. Es sollte also beim Start sichergestellt werden, dass solche Komponenten nicht mitstarten.
    Machen Sie mal bitte folgendes:
    • Prüfen Sie, ob sich im Lizenzverzeichnis %COMMONPROGRAMFILES%\FFUMS\License nur jeweils eine Basislizenz (xx-xxxxxxx.flf) befindet. Mehrere Basislizenzen verwirren das Lizenzmodul und blockieren möglicherweise die Komponenten.
    • Stoppen Sie alle nicht notwendigen Komponenten FileGW und MailGW.
    • Aktualisieren Sie das Jobrouting. (Links unten Jobrouting > Doppelklick > Rechts unten > Knopf "Neu Berechnen" anklicken)
    • Starten Sie nun den Dienst "OfficeMaster Messaging Server" neu. (net stop fmsrv, net start fmsrv)
    Ändert sich nun am Lizenzverhalten etwas?
    Zuletzt geändert von Marko Riebe; 28.07.2011, 14:43. Grund: Formatierung korrigiert.
      ja der Dienst lässt sich jetzt starten. Es war das MailGW. Dafür bekomme ich jetzt aber noch weitere Lizenzfehler:
      Neustart Dienst OfficeMaster Messaging Server
      Opened on Thu Jul 28 16:11:39 2011
      (632) 11/07/28 16:11:39 - DEBUG:   Start: Open Registry hive.
      (3680) 11/07/28 16:11:46 - ERROR:   MapiSaveNDRAsMsg: Attachment cannot be opened. (Code: 0x8004010f)
      (3680) 11/07/28 16:11:47 - ERROR:   Error --> [0x8004010f] (CDO) The value was not found.
      (3680) 11/07/28 16:11:48 - WARNING: MapiCheckInboxFolder: A message cannot be saved.
      (3680) 11/07/28 16:11:48 - ERROR:   MapiSaveNDRAsMsg: Attachment cannot be opened. (Code: 0x8004010f)
      (3680) 11/07/28 16:11:49 - ERROR:   Error --> [0x8004010f] (CDO) The value was not found.
      (3680) 11/07/28 16:11:50 - WARNING: MapiCheckInboxFolder: A message cannot be saved.
      Wo könnte jetzt noch der Fehler liegen?
      Danke
      Zuletzt geändert von Marko Riebe; 28.07.2011, 18:37. Grund: Log auf das Wesentliche gekürzt.
        Startfehler bei der Komponente msx2kgate0
        hier bekommt der Service Account Nachrichten, die das Gateway für NDR-Reports hält. Öffnen Sie das Postfach des Dienstkontos mit OWA und untersuchen Sie bitte die Nachrichten. Das Postfach sollte leer sein. Ich nehme an, es liegen beschädigte NDR-Reports oder Spam (getarnt als NDR) in diesem Postfach.
