ich bekomme immer den oben stehenden Fehler.
Folgendes steht im Logfile:
Opened on Wed Jul 27 17:55:10 2011
Library version 4.0.2.24052
(4276) 11/07/27 17:55:10 - DEBUG: Start: Open Registry hive.
(4276) 11/07/27 17:55:10 - DEBUG: Start: HKCU Hive open.
(4276) 11/07/27 17:55:10 - DEBUG: Start: Local Machine Hive open.
(4276) 11/07/27 17:55:10 - INFO: CreateDefCfg(): Creating a default configuration unit.
(4276) 11/07/27 17:55:10 - DEBUG: MakeDirs(): Creating ']CNV_MOUNT_CENTRAL[/work/msx2kgate0/in'.
(4276) 11/07/27 17:55:10 - DEBUG: MakeDirs(): Creating ']CNV_MOUNT_CENTRAL[/work/msx2kgate0/out'.
(4276) 11/07/27 17:55:10 - DEBUG: MakeDirs(): Creating 'C:\ProgramData\FFUMS\fmsrv/work/msx2kgate0/tmp'.
(4276) 11/07/27 17:55:10 - DEBUG: MakeDirs(): Creating 'C:\ProgramData\FFUMS\fmsrv/work/msx2kgate0/metacache'.
(4276) 11/07/27 17:55:10 - DEBUG: MakeDirs(): Creating 'C:\ProgramData\FFUMS\fmsrv/work/msx2kgate0/undeliverable'.
(4276) 11/07/27 17:55:10 - DEBUG: MakeDirs(): Creating 'C:\ProgramData\FFUMS\fmsrv/work/msx2kgate0/error'.
(4276) 11/07/27 17:55:10 - DEBUG: MakeDirs(): Path 'C:\ProgramData\FFUMS\fmsrv/data/stationery' opened.
(4276) 11/07/27 17:55:10 - DEBUG: License Check: The license parameter 'Enable' for code '50' could not be read.
(4276) 11/07/27 17:55:10 - DEBUG: License Check: The license parameter 'MajorVersion' for code '50' could not be read.
(4276) 11/07/27 17:55:10 - DEBUG: License Check: The license parameter 'MinorVersion' for code '50' could not be read.
(4276) 11/07/27 17:55:10 - ERROR: License Check: At least one service is not licensed anymore (Fax: 0, SMS: 0, Voice: 1).
Closed on Wed Jul 27 17:55:14 2011
Ist da das Lizenzfile defekt oder wo könnte ich noch nach dem Fehler suchen.
Installiert ist OfficeMaster 4.0 Basislizenz
Vielen Dank
Vielen Dank
