Hallo
nachdem unser Ferrari nun fleißig gearbeitet hat wie er soll, gibt es nun akut wieder ein Problem mit dem Konverter conv0
Voran gegangen sind weder Änderungen am Setup oder sonstige Veränderungen, daher kann ich mir den Fehler wirklich nicht erklären
das log von conv0
das log von conv0
(4948) 12/06/25 18:00:53 - INFO: ConvertFile(): converting 'C:\ProgramData\FFUMS\fmsrv/work/conv0/work/0002aad4.RTF' (RTF_PH) to 'C:\ProgramData\FFUMS\fmsrv/work/conv0/work/0002aad5.rtf' (RTF).
(4948) 12/06/25 18:00:53 - INFO: ConvertFile(): converting 'C:\ProgramData\FFUMS\fmsrv/work/conv0/work/0002aad5.rtf' (RTF) to 'C:\ProgramData\FFUMS\fmsrv/work/conv0/work/0002aad6.dcx' (DCX_FAX).
(4960) 12/06/25 18:00:53 - INFO: FFCNV32: ConvertThread(): converter ID=80000003 for 'C:\ProgramData\FFUMS\fmsrv\work\conv0\work\0002aa d5.rtf'
(4960) 12/06/25 18:00:54 - ERROR: FFCNV32: Fehler in Dokumentdrucken:80010001
(4960) 12/06/25 18:00:54 - ERROR: FFCNV32: PrintWordObject-Error!
(4960) 12/06/25 18:00:54 - ERROR: FFCNV32: ExecOle() schlug fehl
(4960) 12/06/25 18:00:54 - ERROR: FFCNV32: FFaxConvertError: File:C:\ProgramData\FFUMS\fmsrv\work\conv0\work\00 02aad5.rtf
(4948) 12/06/25 18:00:54 - ERROR: FFCNV32: FFaxCnvPrint-Error:PrintOle
(4948) 12/06/25 18:00:54 - ERROR: ConvertFile(): conversion from C:\ProgramData\FFUMS\fmsrv\work\conv0\work\0002aad 5.rtf (RTF) to C:\ProgramData\FFUMS\fmsrv\work\conv0\work\0002aad 6.dcx (DCX_FAX) has failed.
(4948) 12/06/25 18:00:54 - ERROR: ConvertDocument(): source file format DCX_FAX does not exist.
(4948) 12/06/25 18:00:54 - DEBUG: OnJobSubmitReq() nach ConvertJob
(4948) 12/06/25 18:00:54 - ERROR: [libagent] MoveJobFile(): snfs_rename(C:\ProgramData\FFUMS\fmsrv/work/conv0/work/0002aad5.rtf,]CNV_MOUNT_CENTRAL[/work/conv0/out/0002aad5.rtf) failed because of 'Permission denied'.
(4948) 12/06/25 18:00:54 - ERROR: [libagent] MoveJobFile(): snfs_rename(]CNV_MOUNT_CENTRAL[/work/conv0/out/0002aad4.RTF,C:\ProgramData\FFUMS\fmsrv/work/conv0/work/0002aad4.RTF) failed because of 'No such file or directory'.
(4948) 12/06/25 18:00:54 - WARNING: OnJobSubmitReq(): Job 174803 cannot be moved from 'C:\ProgramData\FFUMS\fmsrv/work/conv0/work' to ']CNV_MOUNT_CENTRAL[/work/conv0/out': 'No error'.
(4948) 12/06/25 18:00:54 - DEBUG: OnJobSubmitReq() nach FoamFreeDataUnit
(4948) 12/06/25 18:00:54 - INFO: Job 174803 submitted.
(4948) 12/06/25 18:00:54 - DEBUG: OnJobSubmitReq() end
(4948) 12/06/25 18:00:54 - DEBUG: OnMsgReceive end
(4948) 12/06/25 18:00:54 - DEBUG: OnMsgReceive start
(4948) 12/06/25 18:00:54 - WARNING: OnJobSubmitConf(): negative confirmation 12296 for job 174803.
