- Follow codec offer for DTMF on incoming call
- faxt38.prc: support CRP command after PPS
- Config set for NFON SIP trunk added
- Do not support CN codec 13 if VAD is not enabled
- Handle additional interconnect parameters from configuration
- Fax: Do not send NSF by default, can be re-activated via --send-nsf=1
- Use "$uniqueId" in replacement for calling party number or calling party number two and it will be replaced by unique id
- Hold after 15 minutes call duration results in oneway audio
- WebUI: Scan SIP destination scans port 5060 even if rule uses mode "OfficeMaster"
- Answer additional t38 re-INVITES (Session refresh)
- rtp.prc in endless CPU hogging loop when client uses MoH/a=sendrecv
- No ISDN message if SETUP is ignored twice; Resource blocked if PCM is used
- Allow SNMP and SERVERVIEW if firewall is enabled
- faxt38.prc delay for 14400 short training increased: 300 --> 500 msec
- Interface state for S0/BRI was shown as down for a short period after call
- jobcontrol (OfficeMaster) jobs were not counted as active calls on interface state
- Less debug messages from XHFC (BRI interface chip)
- Record-Route needs to be checked before sending "BYE" to determine the correct IP-Address
- Use "Contact" header to initialize incoming call
