Web Interface
Firmware
KNOWN ISSUES
- prohibit starting a test call when a test call is already running
 - web UI stopped running on systems with large rule sets
 - wrong web interface (old vs. new version) was displayed in some cases
Firmware
- new FPGA Version for OfficeMaster Gate Advanced (requires power cycle)
- tool added to create certificate requests or self signed certificates
 - send "not acceptable here" if own callid is referred in replaces header
- support DTMF '#' character as SIPINFO
 - comfort noise was activated too often
 - optimizations for Alcatel OXE call handling
- handles one way audio if partner is changed due to data arriving before reinvite
 - change VIA in PRACK due to CSEQ change
 - encryption errors if destination sends first packet late, SRTP is not used and TLS on SIP is active
 - fax T.38
- after late reINVITE L_FRAME_BEGIN during CED transmiassion caused T.30 to abort
 - several corrections for different timings of CED/CNG etc.
KNOWN ISSUES
- with activated firewall monitoring via second/external NIC is blocked
