- Firmware 4.0.90 brings a lot of new features and some bugfixes
- Additionally there is a new OfficeMaster Gate Configuration online.
FEATURES
- Faster start of call instances for increased scaleability
- Support for up to 64 D-Channels
- Alphanumeric support in SIP-Addresses for better interop with legacy PBX-Systems
- New parameter --NoDialToneHandling to disable dialtone handling
- Experimental support for ISDN devices in point to multipoint mode
- No reboot needed on ISDN log level change, configuration automatically updated after 30 seconds
- New option to set temporary IP settings in omgmenu (console)
- Experimental feature: support for bonding (NIC teaming)
BUGFIXES
- Fixed resource leak when OfficeMaster Gate provides ringback tone to PBX in a drop and insert scenario
- Dial tone did not always play to PBX
- Automatic TON (type of number) handling now also for CallingPartyNumber 2
- Added --noDtmfLoopDetection parameter to avoid doubling DTMF digits
- Set DNS timeout to 3s and no retry to avoid delays when DNS1 not available
- Routing to registered SIP devices didn't work in some situations
- Don't send SIP header OM-ISDN-STATUS Code anymore; use Q850 instead
- Some sipgate provider settings are not set in presets for trunks
- Local syslog in gateway should not fill up file system – oldest logs are deleted automatically
- Recording calls (using --SaveWaveFile) should not fill up file system – oldest logs are deleted automatically
- Increased stability under heavy load
- Analog Ports (FXS card) caused problems under heavy system load
- Support for source IP address as an optional requirement in a call handling rule
- Syslog Analyzer: Great new feature to select a single call with different details through context menu via right click
