Firmware 5.1.90 (2021-10-01)
    Fixed: Timeout on outgoing call due to no answer gives unknown SIP-command
    Fixed: Immediate suspend on sleep-button
    Fixed: Silence suppression off and echo canceller off are lost on error 403
    Fixed: Bad audio quality on codec translation
    Fixed: Number list only checked once
    Fixed: omgconfiginfo crash, if only one trunk is configured
    Fixed: New hostname set by cockpit will be overwritten
    Fixed: Several installation issues
    Fixed: Messages in suspend state, caused by slow or unreachable DNS, cause traceback and loss of layer 4 channel.
    Fixed: Wrong channel count in multitrunk mode
    Fixed: Invite is send to 5060 instead of 5061, if TLS
    Fixed: Transcoding G711 to G722 speeds up voice
    Fixed: Use prefered codec
    Fixed: 603 Decline error transparency
    Fixed: DNS failover on 486 Busy cause
    Fixed: Handle domains with more than 60 IP addresses
    Fixed: Blocking rules result in empty DNS querys
    Fixed: 404 not found error transparency
    Fixed: Wrong port in Contact, From, To field on multiple certificate/TLS-port installations
    Added: Clear path support in SDP
    Added: Support of company flex / 1tr119
    Added: Continuous rtp stream, even during silenc
    Zuletzt geändert von Bert Mittelstedt; 01.10.2021, 14:22.
