Ich habe Exchange 2010. Der Faxserver läuft auf einem Win7 ohne FW, UAC.
Wenn ich ein Fax sende, wird es abgearbeitet, landet aber in der Queue wieder. Im msx2gate0.0-Log habe ich folgende Einträge zu dem Vorgang:
(4976) 10/06/23 16:09:24 - INFO: OnJobSubmitReq(): Set thread credit '9'.
(4976) 10/06/23 16:09:24 - INFO: Job 222 accepted.
(4976) 10/06/23 16:09:24 - INFO: GetOriginatorData: Administrator <Administrator@sachsenkuechen.de>[SMTP:Administrator@sachsenkuechen.de]
(4976) 10/06/23 16:09:24 - INFO: ADsGetUserAttributeCache: Object 'CN=Administrator,CN=Users,DC=s...' cached successfully.
(4976) 10/06/23 16:09:24 - INFO: SendFaxJobToMessagingServer: [0x000000e0 (224)] The created foam job was successfully submitted to CTRL.
(4068) 10/06/23 16:09:33 - INFO: OnJobSubmitReq(): Set thread credit '9'.
(4068) 10/06/23 16:09:33 - INFO: Status message for job 224 received.
(4068) 10/06/23 16:09:33 - INFO: Incoming Status: Job status [0x000000e0] (224) will be processed...
(4068) 10/06/23 16:09:34 - INFO: PreProcessSingleJobStatus: [0x000000e9 (233)] The created foam job was successfully submitted to CTRL.
(4068) 10/06/23 16:09:34 - INFO: Incoming Status: Job status [0x000000e0] (224) is processed.
(1384) 10/06/23 16:09:34 - INFO: OnJobSubmitReq(): Set thread credit '9'.
(1384) 10/06/23 16:09:34 - INFO: Status message for job 233 received.
(1384) 10/06/23 16:09:34 - INFO: Incoming Status: Job status [0x000000e9] (233) will be processed...
(1384) 10/06/23 16:09:43 - ERROR: SendJobToMSX: (222) 4.7.0 Temporary authentication failure
(1384) 10/06/23 16:09:43 - ERROR: ProcessSingleJobStatus: Exchange Server post processing of DRM {2/3/6} failed.
(1384) 10/06/23 16:09:43 - ERROR: Incoming Status: Preprocess job [0x000000e9] (233) cannot be processed.
(1384) 10/06/23 16:09:43 - WARNING: RequeueJob: The job [0x000000ee] (238) will be #1 time requeued.
Den Empfangsconnector habe ich nicht geändert, ich kann Telnet auf Port 10025 vom Faxserver aus machen.
Hat jemand eine Idee?
Vielen Dank
Katrin Rückbrod
Vielen Dank
Katrin Rückbrod
