Fehler nach Update auf 3.1.5.0
    Wir benutzen den LPD-Dienst zum Erstellen von E-Mails/Faxen aus unserem ERP-System. Nach dem Update von 3.1.3.2 auf 3.1.5.0 funktioniert dieser Weg nicht mehr.
    Als Gateway-Komponente ist msx2kgate0 eingetragen. Im Log erscheinen nach dem Druck folgende Meldungen:
    (2468) 10/02/07 18:03:37 - INFO: Incoming Status: Job status [0x004b63cd] (4940749) is processed.
    (616) 10/02/07 18:08:11 - INFO: OnJobSubmitReq(): Set thread credit '9'.
    (616) 10/02/07 18:08:11 - INFO: Job 4940750 accepted.
    (616) 10/02/07 18:08:11 - INFO: Incoming Document: LPD/AppliCOM Job [0x004b63ce] (4940750) will be processed...
    (616) 10/02/07 18:08:12 - INFO: ADsGetUserAttributeCache: Object 'CN=OfficeMaster,CN=Users,DC=DE...' cached successfully.
    (616) 10/02/07 18:08:14 - INFO: PreProcessLPDMailJob: [0x004b63d2 (4940754)] The created foam job was successfully submitted to CTRL.
    (616) 10/02/07 18:08:14 - INFO: Incoming Document: LPD/AppliCOM Job [0x004b63ce] (4940750) is processed.
    (1504) 10/02/07 18:08:14 - INFO: OnJobSubmitReq(): Set thread credit '9'.
    (1504) 10/02/07 18:08:14 - INFO: Status message for job 4940754 received.
    (1504) 10/02/07 18:08:14 - INFO: Incoming Status: Job status [0x004b63d2] (4940754) will be processed...
    (1504) 10/02/07 18:08:14 - ERROR: ProcessLPDMail: Attachment cannot be added. Error: This function is not implemented yet!
    (1504) 10/02/07 18:08:14 - INFO: PreProcessLPDMailJob: [0x004b63d6 (4940758)] The created foam job was successfully submitted to CTRL.
    (1504) 10/02/07 18:08:14 - INFO: Incoming Status: Job status [0x004b63d2] (4940754) is processed.
    (908) 10/02/07 18:08:14 - INFO: OnJobSubmitReq(): Set thread credit '9'.
    (908) 10/02/07 18:08:14 - INFO: Status message for job 4940758 received.
    (908) 10/02/07 18:08:14 - INFO: Incoming Status: Job status [0x004b63d6] (4940758) will be processed...
    (908) 10/02/07 18:08:14 - ERROR: Incoming Status: LPD Mail Status [0x004b63d6] (4940758) will be skipped.
    (908) 10/02/07 18:08:14 - INFO: Incoming Status: Job status [0x004b63d6] (4940758) is processed.
    Wurden mit der aktuellen Version bestehende Funktionen deaktiviert?
    dieses Problem hat seinen Ursprung im Umstieg zu einer neuen Mime-Coder-Bibliothek. Im nächsten Release (OfficeMaster für Exchange Version 3.1.5.2/ OfficeMaster für Exchange 2010 Version 3.5.0.2) des OfficeMasters wird das Problem behoben sein. Lassen Sie sich bitte von der Hotline eine Prerelease-Version 7.1.4.3 der Komponente msx2kgate schicken.
