Fehler bei Exchange 2007 anmeldung
    Hallo Leute folgende Fehler sind im Fehlerprotokoll:
    (3784) 09/07/08 12:01:19 - WARNING: RequeueJob: The job [0x000004bc] (1212) will be requeued for #66 time.
    (3900) 09/07/08 12:01:19 - INFO: Status message for job 1083 received.
    (3900) 09/07/08 12:01:19 - INFO: Incoming Status: Job status [0x0000043b] (1083) will be processed...
    (3900) 09/07/08 12:01:19 - ERROR: CreateInboundHTMLBodyText: Specified HTL Template is invalid.
    (3900) 09/07/08 12:01:19 - WARNING: CreateInboundHTMLBodyText: Creating alternative HTML source due to error in process.
    (3900) 09/07/08 12:01:19 - ERROR: CreateStatusHTMLBodyText: Specified HTL Template is invalid.
    (3900) 09/07/08 12:01:19 - WARNING: CreateStatusHTMLBodyText: Creating alternative HTML source due to error in process.
    (2264) 09/07/08 12:01:24 - ERROR: SendJobToMSX: (0) 4.7.0 Temporary authentication failure
    (2264) 09/07/08 12:01:24 - ERROR: ProcessIncomingFax: Exchange Server post processing failed.
    (2264) 09/07/08 12:01:24 - ERROR: Incoming Status: Fax message [0x00000456] (1110) cannot be processed.
    (2264) 09/07/08 12:01:25 - WARNING: RequeueJob: The job [0x000004c0] (1216) will be requeued for #72 time.
    (1108) 09/07/08 12:01:25 - INFO: Status message for job 1087 received.
    (1108) 09/07/08 12:01:25 - INFO: Incoming Status: Job status [0x0000043f] (1087) will be processed...
    (1108) 09/07/08 12:01:25 - ERROR: CreateInboundHTMLBodyText: Specified HTL Template is invalid.
    (1108) 09/07/08 12:01:25 - WARNING: CreateInboundHTMLBodyText: Creating alternative HTML source due to error in process.
    (1108) 09/07/08 12:01:25 - ERROR: CreateStatusHTMLBodyText: Specified HTL Template is invalid.
    (1108) 09/07/08 12:01:25 - WARNING: CreateStatusHTMLBodyText: Creating alternative HTML source due to error in process.
    (2296) 09/07/08 12:01:30 - ERROR: SendJobToMSX: (0) 4.7.0 Temporary authentication failure
    (2296) 09/07/08 12:01:30 - ERROR: ProcessIncomingFax: Exchange Server post processing failed.
    (2296) 09/07/08 12:01:30 - ERROR: Incoming Status: Fax message [0x0000045a] (1114) cannot be processed.
    (2296) 09/07/08 12:01:30 - WARNING: RequeueJob: The job [0x000004c4] (1220) will be requeued for #72 time.
    (1740) 09/07/08 12:01:30 - INFO: Status message for job 1091 received.
    (1740) 09/07/08 12:01:30 - INFO: Incoming Status: Job status [0x00000443] (1091) will be processed...
    (1740) 09/07/08 12:01:30 - ERROR: CreateInboundHTMLBodyText: Specified HTL Template is invalid.
    (1740) 09/07/08 12:01:30 - WARNING: CreateInboundHTMLBodyText: Creating alternative HTML source due to error in process.
    (1740) 09/07/08 12:01:30 - ERROR: CreateStatusHTMLBodyText: Specified HTL Template is invalid.
    (1740) 09/07/08 12:01:30 - WARNING: CreateStatusHTMLBodyText: Creating alternative HTML source due to error in process.
    Irgend jemand eine Idee ?
    "ERROR: SendJobToMSX: (0) 4.7.0 Temporary authentication failure"
    deutet auf ein Rechteproblem. Sind die Nutzerrechte für den Dienstaccount richtig gesetzt?
    Für eine detailliertere Analyse würde ich hier auf unsere Hotline verweisen.
      Nutzerrechte Sind wie in der Installation beschrieben.
      User und Exchange View Only Administrator.
        SendJobToMSX: (1305920) 4.7.0 Temporary authentication failure
        Hallöchen,
        was ist denn hier nun herausgekommen?
        Wäre schön wenn ein Thread auch zuende geführt werden würde
        Habe ein sehr ähnliches Problem (andere Fehler-ID)....
        Das msx2kgate0.0 meldet "SendJobToMSX: (1305920) 4.7.0 Temporary authentication failure".
        Log:
        (676) 11/04/27 08:08:26 - INFO: Metacache_GetUMCValue: Replicate monthly each 1. day at month at 00:00h.
        (4468) 11/04/27 08:21:43 - ERROR: CreateStatusHTMLBodyText: Specified HTL Template is invalid.
        (4468) 11/04/27 08:21:43 - WARNING: CreateStatusHTMLBodyText: Creating alternative HTML source due to error in process.
        (4468) 11/04/27 08:21:48 - ERROR: SendJobToMSX: (1305920) 4.7.0 Temporary authentication failure
        (4468) 11/04/27 08:21:48 - ERROR: ProcessSingleSMSStatus: Exchange Server post processing failed.
        (4468) 11/04/27 08:21:48 - WARNING: RequeueJob: The job [0x0013fba1] (1309601) will be requeued for #46 time.
        (6164) 11/04/27 08:21:48 - INFO: Status message for job 1309517 received.
        (6164) 11/04/27 08:21:48 - INFO: Incoming Status: Job status [0x0013fb4d] (1309517) will be processed...
        (676) 11/04/27 08:23:33 - INFO: Metacache_GetUMCValue: Replicate monthly each 1. day at month at 00:00h.
        ...komischerweise ist dieses Problem spontan seit etwa Ende vorletzter Woche aufgetreten..
        Systemumgebung:
        Windows 2003 x64 Server R2 SP2
        Exchange 2007 SP3 RU3-v2
        Officemaster 3.1.3.2
        FQDN: Exchange64.domain*.local
        Clientdomain: clients.subdomain*.domain*.local
        Officemaster-Dienstkonto steht in "CN=OMSDIENSTKONTO,CN=Users,DC=subdomain*,DC=domai n*,DC=local"
        Officemaster-Servicekonto hat folgende Rechte
        subdomain*.domain*.local\Domänen-Benutzer
        Exchange-View-Only-Admins
        ...alles nach Anleitung eben...
        Die OfficeMaster-Lizenzgruppe ist eine "Universelle Gruppe" aus der "domain*.local" in der eben auch die entspr. berechtigten User aus der "subdomain*.domain*.local" zugeordnet wurden.
        Wie gesagt, das lief alles die letzten 2 Jahre fehlerfrei!! also kann hier keine Fehlkonfiguration vorliegen...
        Vorab vielen lieben Dank schon mal im Voraus
        Zuletzt geändert von basics; 27.04.2011, 12:24. Grund: Highlighting ;-)
        ________________________________________
        Danke schön, Andy
          Hallo Andy,
          wenn ich auf meinen Kalender schaue, fällt mir auf das am 13.04. Microsoft "spontan" einen Patchday hatte....
          Wenn sich der alte Service Account nicht mehr reanimieren läßt, lege doch einfach einen neuen User an (Domänen-User / MSX View Only / lokaler Admin).
          sichere dir die Konfig in der MSX Exchange Verwaltung (Screenshot oder einfach die eingestellten Werte merken) und installiere den Connector im MessagingServer neu (neuen ServiceAccount angeben).
          Anschliessend nochmal in die MSX Verwaltung und Standardempfänger und Co. wieder setzen und prüfen ob die Mails nun abgesetzt werden können.
          mfg
          Andreas Fechner
            Solved: 4.7.0 Temporary authentication failure
            Hallöchen,
            Problem gelöst!
            Vielen dank an Herrn Fechner!
            Nach dem Neuanlegen von Service-Account mit allen Rechten (Exchange-ViewOnly; Lokaler Admin auf Exchange und Std - Domänen-Benutzer),
            Funktioniert mit vorherigem Sichern des Connectors und der Globalen Einstellungen mit anschließendem Anpassen auf den neuen ServiceAccount alles wieder wie gehabt.
            Nochmals Danke schön.
            Closed
            Danke schön, Andy
