Hallo
Wieder ein kleines Problem:
Situation:
- Server SBS 2003 mit Exchange 2003
- Server 2008 x64Bit Domänen Controller mit Officemaster 3.x (neuste Version)
- \\VSLBGS001\Faxprotokoll (Drucker HP LJ 4250 PCL6) auf Windows 2008 x64
Ist es einbekanntes Problem unter Windows 2008 x64 oder nicht !?!
Warum kommt der HTML body Fehler !?! Liegt es daran !?!
Bitte um kurze Rückmeldung !!
Auszug aus mx2kgate
(6400) 09/07/02 12:07:47 - INFO: Job 10003 accepted.
(6400) 09/07/02 12:07:47 - INFO: GetOriginatorData: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx] HABE ICH UNKENNTLICH GEMACHT !!!
(6400) 09/07/02 12:07:47 - INFO: SendFaxJobToMessagingServer: [0x00002715 (10005)] The created foam job was successfully submitted to CTRL.
(7608) 09/07/02 12:08:29 - INFO: Status message for job 10014 received.
(7608) 09/07/02 12:08:29 - INFO: Incoming Status: Job status [0x0000271e] (10014) will be processed...
(7608) 09/07/02 12:08:30 - INFO: PreProcessSingleJobStatus: [0x00002723 (10019)] The created foam job was successfully submitted to CTRL.
(7608) 09/07/02 12:08:30 - INFO: Incoming Status: Job status [0x0000271e] (10014) is processed.
(7972) 09/07/02 12:08:30 - INFO: Status message for job 10019 received.
(7972) 09/07/02 12:08:30 - INFO: Incoming Status: Job status [0x00002723] (10019) will be processed...
(7972) 09/07/02 12:08:31 - ERROR: CreateStatusHTMLBodyText: Specified HTL Template is invalid.
(7972) 09/07/02 12:08:31 - WARNING: CreateStatusHTMLBodyText: Creating alternative HTML source due to error in process.
(7972) 09/07/02 12:08:31 - INFO: SendJobToMSX: (10003) Mail processed with '2.6.0 Queued mail for delivery'.
(7972) 09/07/02 12:08:31 - ERROR: PrintFax: TIF file 'c:\programdata\ffums\fmsrv/work/msx2kgate0/tmp\00002722.tif' cannot be printed by print engine.
(7972) 09/07/02 12:08:31 - ERROR: PrintFax: Print context for '\\vlbgs001\FaxProtokoll' cannot be opened!
(7972) 09/07/02 12:08:31 - WARNING: ProcessSingleJobStatus: Document cannot be printed.
(7972) 09/07/02 12:08:31 - INFO: Incoming Status: Job status [0x00002723] (10019) is processed.
(708) 09/07/02 12:10:20 - INFO: Metacache_GetUMCValue: Replicate dayly at 00:00h.
Danke
Situation:
Auszug aus mx2kgate
Danke
