wir migrieren zur Zeit unseren Exchange2010-Server auf 2013.
Seit dem 4.12. bekommen wir keine Faxe mehr. Wir haben zu diesem Zeitpunkt die ersten Postfächer auf den neuen Server migriert. Das Officemaster-Postfach und der Connector laufen weiterhin auf dem 2010er-Server, der auch noch alle Rollen hat.
Auszug aus dem Log von msx2kgate0-Log:
Opened on Sun Dec 08 12:30:15 2013
Library version 4.2.2.27043
(3932) 13/12/08 12:30:15 - INFO: CreateDefCfg(): Creating a default configuration unit.
(3932) 13/12/08 12:30:15 - INFO: License Check: Licensed version '4.0'.
(3932) 13/12/08 12:30:15 - INFO: License Check: Maximum users: Fax: -1, SMS: -1, Voice: -1.
(3932) 13/12/08 12:30:15 - INFO: RegisterAgent: Set 10 threads for job processing.
(3932) 13/12/08 12:30:15 - INFO: Loading Active Directory Configuration...
(3932) 13/12/08 12:30:19 - INFO: Attached to 'Connector for UMS (XMAILECG-FERRARIFAX)'.
(3932) 13/12/08 12:30:19 - INFO: Exchange Server 2010 detected. Please restart if Exchange Server entry changes.
(3932) 13/12/08 12:30:19 - INFO: There is at least one configured SMTP Address Space for FAX (fax.XMAILECG).
(3932) 13/12/08 12:30:19 - INFO: The Connector has no SMTP Address Space for SMS.
(3932) 13/12/08 12:30:19 - INFO: The Connector has no SMTP Address Space for Voice.
(3932) 13/12/08 12:30:19 - INFO: Special Recipient Fax Domain: fax.XMAILECG
(3932) 13/12/08 12:30:19 - INFO: Special Recipient SMS Domain: <no entry>
(3932) 13/12/08 12:30:19 - INFO: Special Recipient Vox Domain: <no entry>
(3932) 13/12/08 12:30:19 - INFO: Active Directory initialization succeeded.
(3932) 13/12/08 12:30:19 - INFO: CreateMapiProfile: 'msx2kgate0'.
(3932) 13/12/08 12:30:19 - INFO: Autodiscover: HomeDSA 'XMAILECG' --> '192.168.50.5'
(3932) 13/12/08 12:30:37 - ERROR: OpenInterface2007: Default message store could not be opened. (Code: 0x8004011d)
(3932) 13/12/08 12:30:37 - ERROR: Error --> [0x8004011d] (CDO) The provider failed to connect.
(3932) 13/12/08 12:30:37 - INFO: Start - Gateway cannot be initialized.
Einen anderen zeitlichen Zusammenhang als den oben geschilderten kann ich nicht finden.
Auch nach einem Reboot des Fax-Servers ändert sich nicht.
Der Server ist zwar Windows 2000 aber es läuft nur das OfficeMaster drauf.
Hat jemand eine Idee, warum das passiert, bzw. wie das zu beheben ist ?
mit freundlichen Grüßen
Ralf Balzer
Ralf Balzer
