Fehler beim Faxempfang
    wir haben ein Problem beim Faxempfang. Hier der entsprechende Auszug aus dem Log:
    (4144) 13/08/21 12:20:18 - INFO: <--(3217) :channel_state --channel_name="1.a/B25/S2M/2xG704IDT_E1" --status="+497544966101 --> +49821567128247#" --called_party_number="+49821567128247#" --calling_party_number1="+497544966101" --calling_party_number2="711160690" --redirected_party_number="" --destination="fms" --used
    (4144) 13/08/21 12:20:18 - INFO: <--(3217) :dchannel --message="alerting" --dchannel="jobcontrol_isdn:21297" --channel_id=21297 --calling_party_number="+497544966101" --calling_party_number2="711160690" --called_party_number="8247" --redirecting_number=""
    (4144) 13/08/21 12:20:18 - INFO: DChannel::StartSend(): processing incoming call on OMGAugsburg - D00.
    (4144) 13/08/21 12:20:18 - INFO: [phnumcor] MakePhoneNumExt(): called party number/calling party number/calling party number2/redirection number '8247/+497544966101/711160690/' after regular expression evaluation: '8247/00497544966101/711160690/'.
    (4144) 13/08/21 12:20:18 - INFO: [libagent] get_component_port(): component 'Poll' not found.
    (4144) 13/08/21 12:20:18 - INFO: DChannel::CheckFaxAddr(): no poll definition for 8247.
    (4144) 13/08/21 12:20:18 - INFO: --> :receive --channel_id=21297 --client_id=80225 --command=accept --called_party_number="8247" --calling_party_number="00497544966101" --bchan_exec=fax.prc --bchan_param=" --type=recv --rx-file='[10.80.232.43:49244]/OMCUMS-EXPORT-50946B2A/work/omcums0/rec/00013962.bff' --csid='' --debug-snfs=0 --debug-fc=0 --debug-t30=1 --debug-t4=0 --debug-lapi=0 --debug-modem=0 --bps=14400 --logo=1 --stat-fd=1"
    (4144) 13/08/21 12:20:18 - INFO: <--(3217) :dchannel --message="offhook" --channel_id=21297 --client_id="80225" --dchannel="jobcontrol_isdn:21297"
    (4144) 13/08/21 12:20:18 - INFO: <--(3217) :bchannel --message="start" --client_id="80225" --bchannel="1.a/B25/S2M/2xG704IDT_E1"
    (4144) 13/08/21 12:20:18 - INFO: <--(3217) FAX : rx_file='[10.80.232.43:49244]/OMCUMS-EXPORT-50946B2A/work/omcums0/rec/00013962.bff'
    (4144) 13/08/21 12:20:18 - INFO: <--(3217) FAX : csid=''
    (4144) 13/08/21 12:20:18 - INFO: <--(3217) FAX : argv[0]='fax.prc'
    (4144) 13/08/21 12:20:18 - INFO: <--(3217) FAX : argv[1]='--type=recv'
    (4144) 13/08/21 12:20:18 - INFO: <--(3217) FAX : argv[2]='--interface=1.a/B25/S2M/2xG704IDT_E1'
    (4144) 13/08/21 12:20:18 - INFO: <--(3217) FAX : argv[3]='--stat-fd=1'
    (4144) 13/08/21 12:20:18 - INFO: <--(3217) FAX : argv[4]='--calling-party-number=00497544966101'
    (4144) 13/08/21 12:20:18 - INFO: <--(3217) FAX : argv[5]='--called-party-number=8247'
    (4144) 13/08/21 12:20:18 - INFO: <--(3217) FAX : argv[6]='--type=recv'
    (4144) 13/08/21 12:20:18 - INFO: <--(3217) FAX : argv[7]='--rx-file=[10.80.232.43:49244]/OMCUMS-EXPORT-50946B2A/work/omcums0/rec/00013962.bff'
    (4144) 13/08/21 12:20:18 - INFO: <--(3217) FAX : argv[8]='--csid='
    (4144) 13/08/21 12:20:18 - INFO: <--(3217) FAX : argv[9]='--debug-snfs=0'
    (4144) 13/08/21 12:20:18 - INFO: <--(3217) FAX : argv[10]='--debug-fc=0'
    (4144) 13/08/21 12:20:18 - INFO: <--(3217) FAX : argv[11]='--debug-t30=1'
    (4144) 13/08/21 12:20:18 - INFO: <--(3217) FAX : argv[12]='--debug-t4=0'
    (4144) 13/08/21 12:20:18 - INFO: <--(3217) FAX : argv[13]='--debug-lapi=0'
    (4144) 13/08/21 12:20:18 - INFO: <--(3217) FAX : argv[14]='--debug-modem=0'
    (4144) 13/08/21 12:20:18 - INFO: <--(3217) FAX : argv[15]='--bps=14400'
    (4144) 13/08/21 12:20:18 - INFO: <--(3217) FAX : argv[16]='--logo=1'
    (4144) 13/08/21 12:20:18 - INFO: <--(3217) FAX : argv[17]='--stat-fd=1'
    (4144) 13/08/21 12:20:18 - INFO: <--(3217) :event PRC_STARTED
    (4144) 13/08/21 12:20:18 - WARNING: DChannel::OnMsgLine(): ignoring unknown command ':event PRC_STARTED'.
    (4144) 13/08/21 12:20:18 - INFO: <--(3217) T30 : B25 Wed Aug 21 12:20:18 2013
    (4144) 13/08/21 12:20:18 - INFO: <--(3217) SETUP RX 14400 ECM Fax fine MR/MMR NoPoll
    (4144) 13/08/21 12:20:18 - INFO: <--(3217) :alive
    (4472) 13/08/21 12:20:22 - INFO: <--(3227) :alive
    (4144) 13/08/21 12:20:23 - INFO: <--(3217) T30 : B25 SEND NSF (04 8b 02 01 05 00 00 )
    (4144) 13/08/21 12:20:23 - INFO: <--(3217) T30 : B25 SEND CSI
    (4144) 13/08/21 12:20:23 - INFO: <--(3217) T30 : B25 SEND DIS V17/V33 14400 ECM Fax fine MR/MMR (00 77 1f 22 )
    (4144) 13/08/21 12:20:24 - INFO: <--(3217) :alive
    (4472) 13/08/21 12:20:28 - INFO: <--(3227) :alive
    (4144) 13/08/21 12:20:28 - INFO: <--(3217) Error: T30 B25 12:20:28,363 Unexpected event L_T30_CRP at state T30_PBR_W4DCS.
    (4144) 13/08/21 12:20:29 - INFO: <--(3217) T30 : B25 SendHighLayerKillReq page_count=0
    (4144) 13/08/21 12:20:29 - INFO: <--(3217) T30 : B25 12:20:29,990 Kill Function called
    (4144) 13/08/21 12:20:29 - INFO: <--(3217) :fax --bchannel="1.a/B25/S2M/2xG704IDT_E1" --date="2013-08-21-12:20.29" --error="none" --type="recv" --bps="?" --ecm=0 --res="?" --t4="?" --txp=0 --rxp=0 --ferrari=0 --sernum=0 --csid="" --to="" --from=""
    (4144) 13/08/21 12:20:29 - INFO: DChannel::OnMsgLine(): job 80225: :fax --bchannel="1.a/B25/S2M/2xG704IDT_E1" --date="2013-08-21-12:20.29" --error="none" --type="recv" --bps="?" --ecm=0 --res="?" --t4="?" --txp=0 --rxp=0 --ferrari=0 --sernum=0 --csid="" --to="" --from="".
    (4144) 13/08/21 12:20:29 - INFO: <--(3217) :fax --bchannel="1.a/B25/S2M/2xG704IDT_E1" --date="2013-08-21-12:20.29" --error="t30_error" --type="recv" --bps="?" --ecm=0 --res="?" --t4="?" --txp=0 --rxp=0 --ferrari=0 --sernum=0 --csid="" --to="" --from=""
    (4144) 13/08/21 12:20:29 - INFO: DChannel::OnMsgLine(): job 80225: :fax --bchannel="1.a/B25/S2M/2xG704IDT_E1" --date="2013-08-21-12:20.29" --error="t30_error" --type="recv" --bps="?" --ecm=0 --res="?" --t4="?" --txp=0 --rxp=0 --ferrari=0 --sernum=0 --csid="" --to="" --from="".
    (4144) 13/08/21 12:20:29 - INFO: <--(3217) :bchannel --message="finished" --client_id="80225" --bchannel="1.a/B25/S2M/2xG704IDT_E1"
    (4144) 13/08/21 12:20:30 - INFO: <--(3217) :channel_state --channel_name="1.a/B25/S2M/2xG704IDT_E1" --status="+497544966101 --> +49821567128247#" --called_party_number="+49821567128247#" --calling_party_number1="+497544966101" --calling_party_number2="711160690" --redirected_party_number="" --destination="fms" --ready
    (4144) 13/08/21 12:20:30 - INFO: <--(3217) :dchannel --message="onhook" --channel_id=21297 --client_id="80225" --dchannel="jobcontrol_isdn:21297" --charges=0 --cause=10
    (4144) 13/08/21 12:20:30 - INFO: Discarding message of type 'Rec' to '8247' with status 3 and error code 14.
    (4144) 13/08/21 12:20:30 - INFO: <--(3217) :alive
    Schönes Log....war damit irgendeine Frage verbunden oder wolltest du es uns einfach nur wissen lassen.
    3-14 besagt: keine Antwort auf ein T30 Kommando
    Ralf
      Hallo Herr Jänike,
      da wir wie Beschrieben ein Problem beim Faxempfang haben, würde ich natürlich gerne Wissen, muss ich das Problem bei uns suchen oder liegt es an der Gegenseite? In der Mail vom OfficeMaster steht Folgende Meldung: Fax-API-Fehler (Code: 8, Negative Seitenbestätigung)
      Matthias
        Hallo Matthias,
        die Antwort auf deine Frage findest dur HIER
        mehr lässt sich auf dem Forumweg dazu nicht analysieren
        Ralf
