Guten Morgen an alle,
wir haben W2K8 R2 und OM 64 im Einsatz. Nach dem Update des OM auf die aktuelle Version funktioniert der Connector nicht mehr. DNS und Rechte wurden nicht verändert bzw. funktionieren, der Connector bereits neu installiert.
im log findet man folgendes:
(388) 11/09/16 07:25:46 - INFO: Loading Active Directory Configuration...
(388) 11/09/16 07:25:46 - INFO: Attached to 'Connector for UMS (SBSSTESAD-STPCTI013)'.
(388) 11/09/16 07:25:46 - INFO: ADsGetGlobalAttribute: 'DIR' --> '\\STPCTI013\FFACCESS\'
(388) 11/09/16 07:25:46 - INFO: ADsGetPrimaryDomainName: PMD --> 'Stesad.de'
(388) 11/09/16 07:25:46 - INFO: ADsGetConnectorAttribute: 'MSX' --> 'SBSSTESAD'
(388) 11/09/16 07:25:46 - INFO: Exchange Server 2007 detected. Please restart if Exchange Server entry changes.
(388) 11/09/16 07:25:46 - INFO: ADsGetConnectorAttribute: 'COC' --> '+49'
(388) 11/09/16 07:25:46 - INFO: Set obsolete/compatible country code: '+49'
(388) 11/09/16 07:25:46 - INFO: ADsGetConnectorAttribute: 'UIS' --> '0'
(388) 11/09/16 07:25:46 - INFO: Set UIS setting: '0'
(388) 11/09/16 07:25:46 - INFO: ADsGetConnectorAttribute: 'UTS' --> [EMPTY]
(388) 11/09/16 07:25:46 - INFO: Set Time Stamp setting: '0'
(388) 11/09/16 07:25:46 - INFO: ADsGetConnectorAttribute: 'CNC' --> '0'
(388) 11/09/16 07:25:46 - INFO: Set canonical number correction: '0'
(388) 11/09/16 07:25:46 - INFO: ADsGetFirstSMTPAddressSpace: DN --> 'CN=Connector for UMS (SBSSTESAD-STPCTI013),CN=Connections,CN=Exchange Routing Group (DWBGZMFD01QNBJR),CN=Routing Groups,CN=Exchange Administrative Group (FYDIBOHF23SPDLT),CN=Administrative Groups,CN=STESAD,CN=Microsoft Exchange,CN=Services,CN=Configuration,DC=Stesad,DC =de'
(388) 11/09/16 07:25:46 - INFO: ADsGetFirstSMTPAddressSpace: Got address space 'fax.SBSSTESAD'.
(388) 11/09/16 07:25:46 - INFO: There is at least one configured SMTP Address Space for FAX (fax.SBSSTESAD).
(388) 11/09/16 07:25:46 - ERROR: ADsGetFirstSMTPAddressSpace: DN --> 'CN=Connector for UMS (SBSSTESAD-STPCTI013),CN=Connections,CN=Exchange Routing Group (DWBGZMFD01QNBJR),CN=Routing Groups,CN=Exchange Administrative Group (FYDIBOHF23SPDLT),CN=Administrative Groups,CN=STESAD,CN=Microsoft Exchange,CN=Services,CN=Configuration,DC=Stesad,DC =de'
(388) 11/09/16 07:25:47 - INFO: ADsGetFirstSMTPAddressSpace: There was no smtp address space found.
(388) 11/09/16 07:25:47 - INFO: The Connector has no SMTP Address Space for SMS.
(388) 11/09/16 07:25:47 - ERROR: ADsGetFirstSMTPAddressSpace: DN --> 'CN=Connector for UMS (SBSSTESAD-STPCTI013),CN=Connections,CN=Exchange Routing Group (DWBGZMFD01QNBJR),CN=Routing Groups,CN=Exchange Administrative Group (FYDIBOHF23SPDLT),CN=Administrative Groups,CN=STESAD,CN=Microsoft Exchange,CN=Services,CN=Configuration,DC=Stesad,DC =de'
(388) 11/09/16 07:25:48 - INFO: ADsGetFirstSMTPAddressSpace: There was no smtp address space found.
(388) 11/09/16 07:25:48 - INFO: The Connector has no SMTP Address Space for Voice.
(388) 11/09/16 07:25:48 - INFO: ADsGetConnectorAttribute: 'POM' --> '~E' (Base Node)
(388) 11/09/16 07:25:48 - INFO: Active Directory initialization succeeded.
(388) 11/09/16 07:25:48 - INFO: ADsCheckForPublicFolder: At least one Public Folder Database was found.
(388) 11/09/16 07:25:49 - INFO: CreateMapiProfile: 'msx2kgate0'.
(388) 11/09/16 07:25:49 - INFO: ADsGetConnectorAttribute: 'SME' --> [EMPTY]
(388) 11/09/16 07:25:49 - INFO: Autodiscover: Discover for user 'CN=Detewe,OU=Services,OU=Users,OU=MyBusiness,DC=S tesad,DC=de'.
(388) 11/09/16 07:25:49 - INFO: GetIPAddress: 'SBSSTESAD' --> '192.168.50.20'
(388) 11/09/16 07:25:49 - INFO: Autodiscover: HomeDSA 'SBSSTESAD' --> '192.168.50.20'
(388) 11/09/16 07:25:49 - INFO: ADsGetConnectorAttribute: 'EIP' --> '~E'
(388) 11/09/16 07:25:49 - INFO: Autodiscover: Discover '192.168.50.20/Detewe@stesad.de'.
(388) 11/09/16 07:25:49 - ERROR: CreateMapiProfile: Exchange Message Service cannot be configured. (Code: 0x81002746)
(388) 11/09/16 07:25:50 - ERROR: Error --> [0x81002746] (No error description available)
(388) 11/09/16 07:25:51 - INFO: DeleteMapiProfile: Remove profile 'msx2kgate0'.
(388) 11/09/16 07:25:51 - INFO: DeleteMapiProfile: Profile 'msx2kgate0' removed.
(388) 11/09/16 07:25:51 - INFO: Start - Gateway cannot be initialized.
Closed on Fri Sep 16 07:25:56 2011
vielleicht hat schon jemand eine - vielen Dank im Voraus
