Converter Problem nach Upgrade auf OfficeMaster 6
    ich habe kürzlich ein Upgrade vom OfficeMaster Server Version 5 auf die neue 6.2.5 durchgeführt.
    Das Upgrade selbst lief sauber durch, allerdings macht die Konvertierung nun Probleme.
    Die conv0 Komponente stürzt bei jedem Fax ab und startet neu.
    Folgende Errormeldungen habe ich im Log gesehen:
    (2652) 19/09/10 20:27:58 - INFO: ConvertFile(): converting 'C:\ProgramData\FFUMS\fmsrv/work/conv0/work/00421744.htm' (HTML) to 'C:\ProgramData\FFUMS\fmsrv/work/conv0/work/00421752.dcx' (DCX_FAX).
    (3492) 19/09/10 20:27:58 - INFO: FFCNV32: CnvConvertViaPrint: Printing 'C:\ProgramData\FFUMS\fmsrv/work/conv0/work/00421744.htm' to 'ferrariFAX 64'.
    Opened on Tue Sep 10 20:28:06 2019
    Library version 6.2.5.12733
    (4196) 19/09/10 20:28:06 - INFO: main(): starting version 6.2.5.12733 compiled at Jan 31 2019 on 11:14:00 jenkins-git-MessagingServer6-621-120 running as service
    (4196) 19/09/10 20:28:07 - INFO: SetOleUserSpecific(): add conv from to TIF_TIF
    (4196) 19/09/10 20:28:07 - ERROR: FFCNV32: Cannot terminate process. Id - 4524, Name - \Device\HarddiskVolume1\Windows\splwow64.exe, Error - 5
    (4196) 19/09/10 20:28:07 - INFO: FFCNV32: foleconv is running -> do not kill office processes
    (4196) 19/09/10 20:28:07 - INFO: GetComponentPathMwi(): install state for component '{19E4F719-7A4E-11D4-A600-00A0CC6022F6}' is -1 (INSTALLSTATE_UNKNOWN - The product code or component ID is unknown.).
    (4196) 19/09/10 20:28:07 - INFO: GetComponentPathMwi(): install state for component '{3BDB35F2-A5EF-4FA0-8725-BE8803DD745A}' is -1 (INSTALLSTATE_UNKNOWN - The product code or component ID is unknown.).
    (2132) 19/09/10 20:28:07 - INFO: FFCNV32: setting version information for 'MSOffice' to 0x10008
    (4196) 19/09/10 20:28:07 - INFO: GetComponentPathMwi(): install state for component '{39E14C8C-0F87-4486-9B3A-30F262B85755}' is 3 (INSTALLSTATE_LOCAL - The component is installed locally.).
    (4196) 19/09/10 20:28:07 - INFO: InitJetPcl(): library 'C:\Program Files (x86)\Common Files\FFUMS\Jfax3wnt.dll' loaded.
    (4196) 19/09/10 20:28:07 - INFO: Font index file 'C:\Program Files (x86)\Common Files\FFUMS/if/if.fnt' can be opened.
    (4196) 19/09/10 20:28:07 - INFO: GetComponentPathMwi(): install state for component '{ABBDDC08-40D5-4FF8-BD30-8A6F5E406789}' is -1 (INSTALLSTATE_UNKNOWN - The product code or component ID is unknown.).
    (4196) 19/09/10 20:28:07 - INFO: InitFineReader(): fine reader engine DLL '' cannot be loaded.
    (4196) 19/09/10 20:28:07 - INFO: Microsoft Office Word='C:\Program Files\Microsoft Office\Office14\\winword.exe'
    (4196) 19/09/10 20:28:07 - INFO: Microsoft Office Excel='C:\Program Files\Microsoft Office\Office14\\excel.exe'
    (4196) 19/09/10 20:28:07 - INFO: Microsoft Office PowerPoint='C:\Program Files\Microsoft Office\Office14\\powerpnt.exe'
    (4196) 19/09/10 20:28:07 - INFO: OpenOffice swriter=''
    (4196) 19/09/10 20:28:07 - INFO: OpenOffice scalc=''
    (4196) 19/09/10 20:28:07 - INFO: OpenOffice simpress=''
    (4196) 19/09/10 20:28:07 - INFO: OpenOffice sdraw=''
    (4196) 19/09/10 20:28:09 - INFO: StartPipeServer():Pipe:\\.\pipe\FFPrintToUser_SYST EM not present try to start PipeServer
    (4196) 19/09/10 20:28:09 - INFO: StartPipeServer(): start "C:\Program Files (x86)\FFUMS\ferrariFAX-Client\fftray.exe" -NOICON
    (4196) 19/09/10 20:28:09 - INFO: StartPipeServer(): CreateProcess "C:\Program Files (x86)\FFUMS\ferrariFAX-Client\fftray.exe" -NOICON OK
    Der OleConverter ist im Einsatz auf dem Server.
    Ich würde mich über einen Hinweis freuen.
    Zuletzt geändert von glaefkep; 12.09.2019, 10:49.
