wir haben folgendes Problem:
Wenn mehr als ein PDF in einem Fax angehängt und versendet wird, bekommen wir einen Konvertierungsfehler (Datei-Format-Konvertierungsfehler).
Hier auch ein entsprechender Log-Auszug:
(3240) 10/08/20 11:42:58 - INFO: FFCNV32: ConvertThread(): converter ID=2 for 'C:\Programme\FFUMS\fmsrv\work\conv0\work\0062ed6f .pdf'
(3240) 10/08/20 11:42:58 - INFO: FFCNV32: AcrobatDelay = 100
(3320) 10/08/20 11:45:58 - ERROR: FFCNV32: Timeout during conversion from C:\Programme\FFUMS\fmsrv\work\conv0\work\0062ed6f. pdf to C:\Programme\FFUMS\fmsrv\work\conv0\work\0062ed76. dcx.
(3320) 10/08/20 11:45:58 - ERROR: FFCNV32: ConvertThread stopped, now starting again
(3320) 10/08/20 11:46:02 - ERROR: FFCNV32: FFaxCnvPrint-Error:PrintOle
(832) 10/08/20 11:46:02 - INFO: FFCNV32: Started CentralConvertThread ID: 832, version 3.1.3.0
(3320) 10/08/20 11:46:02 - ERROR: ConvertFile(): conversion from C:\Programme\FFUMS\fmsrv\work\conv0\work\0062ed6f. pdf (PDF) to C:\Programme\FFUMS\fmsrv\work\conv0\work\0062ed76. dcx (DCX_FAX) has failed.
(832) 10/08/20 11:46:02 - INFO: FFCNV32: OleInitialize OK
(3320) 10/08/20 11:46:02 - ERROR: ConvertDocument(): source file format DCX_FAX does not exist.
(3320) 10/08/20 11:46:02 - INFO: ConvertFile(): converting 'C:\Programme\FFUMS\fmsrv/work/conv0/work/0062ed70.pdf' (PDF) to 'C:\Programme\FFUMS\fmsrv/work/conv0/work/0062ed8f.dcx' (DCX_FAX).
(832) 10/08/20 11:46:02 - INFO: FFCNV32: ConvertThread(): converter ID=2 for 'C:\Programme\FFUMS\fmsrv\work\conv0\work\0062ed70 .pdf'
(832) 10/08/20 11:46:02 - INFO: FFCNV32: AcrobatDelay = 100
(3320) 10/08/20 11:46:07 - INFO: ConvertFile(): converting 'C:\Programme\FFUMS\fmsrv/work/conv0/work/0062ed8f.dcx' (DCX_FAX) to 'C:\Programme\FFUMS\fmsrv/work/conv0/work/0062ed92.bff' (BFF).
(3320) 10/08/20 11:46:07 - INFO: ConvertFile(): converting 'C:\Programme\FFUMS\fmsrv/work/conv0/work/0062ed71.pdf' (PDF) to 'C:\Programme\FFUMS\fmsrv/work/conv0/work/0062ed93.dcx' (DCX_FAX).
(832) 10/08/20 11:46:07 - INFO: FFCNV32: ConvertThread(): converter ID=2 for 'C:\Programme\FFUMS\fmsrv\work\conv0\work\0062ed71 .pdf'
(832) 10/08/20 11:46:07 - INFO: FFCNV32: AcrobatDelay = 100
(3320) 10/08/20 11:49:07 - ERROR: FFCNV32: Timeout during conversion from C:\Programme\FFUMS\fmsrv\work\conv0\work\0062ed71. pdf to C:\Programme\FFUMS\fmsrv\work\conv0\work\0062ed93. dcx.
(3320) 10/08/20 11:49:07 - ERROR: FFCNV32: ConvertThread stopped, now starting again
(3320) 10/08/20 11:49:11 - ERROR: FFCNV32: FFaxCnvPrint-Error:PrintOle
(664) 10/08/20 11:49:11 - INFO: FFCNV32: Started CentralConvertThread ID: 664, version 3.1.3.0
(3320) 10/08/20 11:49:11 - ERROR: ConvertFile(): conversion from C:\Programme\FFUMS\fmsrv\work\conv0\work\0062ed71. pdf (PDF) to C:\Programme\FFUMS\fmsrv\work\conv0\work\0062ed93. dcx (DCX_FAX) has failed.
(664) 10/08/20 11:49:11 - INFO: FFCNV32: OleInitialize OK
(3320) 10/08/20 11:49:11 - ERROR: ConvertDocument(): source file format DCX_FAX does not exist.
Wir verwenden Office Master 3.1.4.0 für Lotus Notes und den Acrobat Reader 9.
Vielen Dank für Ihre Untestützung.
