Hallo
ich bekomme auf einmal Fehler bei der Konvertierung von NSF -> DCX_Fax.
Konverter und Server wurden schon neu gestertet leider ohne Erfolg.
Log :
(2064) 15/05/08 11:33:38 - INFO: Job 708916 accepted.
(2064) 15/05/08 11:33:38 - INFO: fms_write_job(): LogInfo ind= 1.
(2064) 15/05/08 11:33:38 - INFO: ConvertFile(): converting 'C:\Programme\FFUMS\fmsrv/data/stationery/DOMSRVLD/Stadt Landau#mail\officema#ef2be.nsf' (NSF) to 'C:\Programme\FFUMS\fmsrv/work/conv0/work/000ad135.dcx' (DCX_FAX).
(336) 15/05/08 11:33:40 - ERROR: FFCNV32: PrintNotesObject EditDocument Error:80020009
(2064) 15/05/08 11:34:38 - ERROR: FFCNV32: Timeout during conversion from DOMSRVLD/Stadt Landau#mail\officema#ef2be.nsf to C:\Programme\FFUMS\fmsrv/work/conv0/work/000ad135.dcx.
(2064) 15/05/08 11:34:38 - ERROR: FFCNV32: stopping ConvertThread, starting again
(2064) 15/05/08 11:34:41 - INFO: FFCNV32: RestartSpooler ready
(2064) 15/05/08 11:34:43 - INFO: FFCNV32: RestartSpooler ready
(2064) 15/05/08 11:34:43 - ERROR: FFCNV32: FFaxCnvPrint-Error:PrintOle
(2064) 15/05/08 11:34:43 - ERROR: ConvertFile(): conversion has failed -->retry.
(2064) 15/05/08 11:34:43 - INFO: ConvertFile(): 2.Trial converting 'C:\Programme\FFUMS\fmsrv/data/stationery/DOMSRVLD/Stadt Landau#mail\officema#ef2be.nsf' (NSF) to 'C:\Programme\FFUMS\fmsrv/work/conv0/work/000ad135.dcx' (DCX_FAX).
(3788) 15/05/08 11:34:46 - ERROR: FFCNV32: PrintNotesObject GetDocumentById Error:80070057
(3788) 15/05/08 11:34:46 - ERROR: FFCNV32: PrintNotesObject Close Error
(3788) 15/05/08 11:34:46 - ERROR: FFCNV32: PrintNotesObject-Error!
(3788) 15/05/08 11:34:47 - INFO: FFCNV32: ExecOle OleCounter=0 OLE_Error=0
(3788) 15/05/08 11:34:47 - ERROR: FFCNV32: ExecOle() schlug fehl
(3788) 15/05/08 11:34:47 - ERROR: FFCNV32: FFaxConvertError: File
(2064) 15/05/08 11:34:47 - ERROR: FFCNV32: FFaxCnvPrint-Error:PrintOle
(2064) 15/05/08 11:34:47 - ERROR: ConvertFile(): conversion from C:\Programme\FFUMS\fmsrv/data/stationery/DOMSRVLD/Stadt Landau#mail\officema#ef2be.nsf (NSF) to C:\Programme\FFUMS\fmsrv/work/conv0/work/000ad135.dcx (DCX_FAX) has finally failed.
(2064) 15/05/08 11:34:47 - INFO: ConvertDocument() (NSF->DCX_FAX) duration : 68946ms Error ok:0 err:13
(2064) 15/05/08 11:34:47 - ERROR: ConvertDocument(): source file format DCX_FAX does not exist.
(2064) 15/05/08 11:34:49 - INFO: StartPipeServer():Pipe:\\.\pipe\FFPrintToUser_SYST EM not present try to start PipeServer
(2064) 15/05/08 11:34:49 - INFO: StartPipeServer(): start "C:\Programme\FFUMS\ferrariFAX-Client\fftray.exe" -NOICON
(2064) 15/05/08 11:34:49 - INFO: StartPipeServer(): CreateProcess "C:\Programme\FFUMS\ferrariFAX-Client\fftray.exe" -NOICON OK
(2064) 15/05/08 11:34:49 - INFO: Job 708916 submitted.
(2064) 15/05/08 11:34:49 - INFO: Job 708918 accepted.
(2064) 15/05/08 11:34:49 - INFO: fms_write_job(): LogInfo ind= 1.
(2064) 15/05/08 11:34:49 - INFO: ConvertFile(): converting 'C:\Programme\FFUMS\fmsrv/data/stationery/DOMSRVLD/Stadt Landau#mail\officema#ef2c6.nsf' (NSF) to 'C:\Programme\FFUMS\fmsrv/work/conv0/work/000ad137.dcx' (DCX_FAX).
(3788) 15/05/08 11:34:51 - ERROR: FFCNV32: PrintNotesObject EditDocument Error:80020009
(2064) 15/05/08 11:35:49 - ERROR: FFCNV32: Timeout during conversion from DOMSRVLD/Stadt Landau#mail\officema#ef2c6.nsf to C:\Programme\FFUMS\fmsrv/work/conv0/work/000ad137.dcx.
(2064) 15/05/08 11:35:49 - ERROR: FFCNV32: stopping ConvertThread, starting again
(2064) 15/05/08 11:35:52 - INFO: FFCNV32: RestartSpooler ready
(2064) 15/05/08 11:35:54 - INFO: FFCNV32: RestartSpooler ready
(2064) 15/05/08 11:35:54 - ERROR: FFCNV32: FFaxCnvPrint-Error:PrintOle
(2064) 15/05/08 11:35:54 - ERROR: ConvertFile(): conversion has failed -->retry.
(2064) 15/05/08 11:35:54 - INFO: ConvertFile(): 2.Trial converting 'C:\Programme\FFUMS\fmsrv/data/stationery/DOMSRVLD/Stadt Landau#mail\officema#ef2c6.nsf' (NSF) to 'C:\Programme\FFUMS\fmsrv/work/conv0/work/000ad137.dcx' (DCX_FAX).
(3952) 15/05/08 11:35:57 - ERROR: FFCNV32: PrintNotesObject GetDocumentById Error:80070057
(3952) 15/05/08 11:35:57 - ERROR: FFCNV32: PrintNotesObject Close Error
(3952) 15/05/08 11:35:57 - ERROR: FFCNV32: PrintNotesObject-Error!
(3952) 15/05/08 11:35:58 - INFO: FFCNV32: ExecOle OleCounter=0 OLE_Error=0
(3952) 15/05/08 11:35:58 - ERROR: FFCNV32: ExecOle() schlug fehl
(3952) 15/05/08 11:35:58 - ERROR: FFCNV32: FFaxConvertError: File
(2064) 15/05/08 11:35:58 - ERROR: FFCNV32: FFaxCnvPrint-Error:PrintOle
(2064) 15/05/08 11:35:58 - ERROR: ConvertFile(): conversion from C:\Programme\FFUMS\fmsrv/data/stationery/DOMSRVLD/Stadt Landau#mail\officema#ef2c6.nsf (NSF) to C:\Programme\FFUMS\fmsrv/work/conv0/work/000ad137.dcx (DCX_FAX) has finally failed.
(2064) 15/05/08 11:35:58 - INFO: ConvertDocument() (NSF->DCX_FAX) duration : 68899ms Error ok:0 err:14
(2064) 15/05/08 11:35:58 - ERROR: ConvertDocument(): source file format DCX_FAX does not exist.
(2064) 15/05/08 11:36:00 - INFO: StartPipeServer():Pipe:\\.\pipe\FFPrintToUser_SYST EM not present try to start PipeServer
(2064) 15/05/08 11:36:00 - INFO: StartPipeServer(): start "C:\Programme\FFUMS\ferrariFAX-Client\fftray.exe" -NOICON
(2064) 15/05/08 11:36:00 - INFO: StartPipeServer(): CreateProcess "C:\Programme\FFUMS\ferrariFAX-Client\fftray.exe" -NOICON OK
(2064) 15/05/08 11:36:00 - INFO: Job 708918 submitted.
Officemaster Version : 4.2.2.27043
Anbindung an Lotus Notes 8
System : Windows 2003 Server R2 - SP2
Mit freundlichen Grüssen
S.Berner
Log :
OMSRVLD/Stadt Landau#mail\officema#ef2be.nsf(2064) 15/05/08 11:34:47 - ERROR: FFCNV32: FFaxCnvPrint-Error:PrintOle
OMSRVLD/Stadt Landau#mail\officema#ef2c6.nsf(2064) 15/05/08 11:35:58 - ERROR: FFCNV32: FFaxCnvPrint-Error:PrintOle
S.Berner
