Guten Tag,
unsere Office-Master Box läuft nicht mehr. Im Komponentenstatus gehen die Kanäle immer wieder in den Wartungsmodus. Nach ein paar Minuten gehen die Kanäle wieder online und man kann sehen, wie ein Fax eingeht. Es kommt aber nicht an... Auszug auf dem Log:
(2748) 09/06/23 09:36:59 - INFO: --> :sh builddate
(2748) 09/06/23 09:37:00 - INFO: <-- Mon Jan 26 00:13:11 UTC 2009
(2748) 09/06/23 09:37:00 - INFO: <-- :sh --status=0
(2748) 09/06/23 09:37:00 - INFO: --> :sh cat /usr/version
(2748) 09/06/23 09:37:01 - INFO: <-- OMG 3.1.6
(2748) 09/06/23 09:37:01 - INFO: <-- :sh --status=0
(2748) 09/06/23 09:37:01 - INFO: --> :env
(2748) 09/06/23 09:37:01 - INFO: <-- :env --val="JCINTERFACE=3"
(2748) 09/06/23 09:37:02 - INFO: <-- :env --val="MWI=embed,calling"
(2748) 09/06/23 09:37:02 - INFO: <-- :env --val="hwsn=197"
(2748) 09/06/23 09:37:11 - INFO: OmcDev::ReadCardEnv(): cannot receive message from 0x4200010a/3217.
(2540) 09/06/23 09:37:11 - INFO: --> :sh builddate
(2748) 09/06/23 09:37:11 - WARNING: DChannel::Connect(): card environment could not be read.
(2540) 09/06/23 09:37:21 - WARNING: OmcSock::ShellCmd(): shell command timeout.
(2540) 09/06/23 09:37:21 - INFO: --> :sh cat /usr/version
(2540) 09/06/23 09:37:21 - INFO: <-- Mon Jan 26 00:13:11 UTC 2009
(2540) 09/06/23 09:37:31 - WARNING: OmcSock::ShellCmd(): shell command timeout.
(2540) 09/06/23 09:37:31 - INFO: --> :env
(2540) 09/06/23 09:37:33 - INFO: <-- :sh --status=0
(2540) 09/06/23 09:37:41 - INFO: OmcDev::ReadCardEnv(): cannot receive message from 0x4200010a/3218.
(2748) 09/06/23 09:37:41 - INFO: --> :sh date 062309372009.41
(2540) 09/06/23 09:37:41 - WARNING: DChannel::Connect(): card environment could not be read.
(2540) 09/06/23 09:37:41 - INFO: --> :sh date 062309372009.41
(2748) 09/06/23 09:37:51 - WARNING: OmcSock::ShellCmd(): shell command timeout.
(2748) 09/06/23 09:37:51 - ERROR: DChannel::SetCardTime(): card time could not be set.
(2748) 09/06/23 09:37:51 - WARNING: DChannel::InitJobControl(): could not set date and time.
(2748) 09/06/23 09:37:51 - WARNING: DChannel::InitJobControl(): initiating maintenance cycle after startup error.
(2748) 09/06/23 09:37:51 - INFO: DChannel::EnterMaintenance(): shortest job abort time=60.
(2748) 09/06/23 09:37:51 - INFO: DChannel::EnterMaintenance(): disconnecting from job control while entering maintenance mode (with corrupt b-channel).
(2748) 09/06/23 09:37:51 - INFO: --> :quit
(2540) 09/06/23 09:37:51 - WARNING: OmcSock::ShellCmd(): shell command timeout.
(2540) 09/06/23 09:37:51 - ERROR: DChannel::SetCardTime(): card time could not be set.
(2540) 09/06/23 09:37:51 - WARNING: DChannel::InitJobControl(): could not set date and time.
(2540) 09/06/23 09:37:51 - WARNING: DChannel::InitJobControl(): initiating maintenance cycle after startup error.
(2540) 09/06/23 09:37:51 - INFO: DChannel::EnterMaintenance(): shortest job abort time=60.
(2540) 09/06/23 09:37:51 - INFO: DChannel::EnterMaintenance(): disconnecting from job control while entering maintenance mode (with corrupt b-channel).
(2540) 09/06/23 09:37:51 - INFO: --> :exit
(2748) 09/06/23 09:38:31 - INFO: DChannel::Connect(): connecting to fax device 10.1.0.66/3217.
(2540) 09/06/23 09:38:31 - INFO: DChannel::Connect(): connecting to fax device 10.1.0.66/3218.
(2748) 09/06/23 09:38:32 - INFO: OmcSock::Connect(): cannot connect socket.
(2748) 09/06/23 09:38:32 - ERROR: DChannel::Connect(): cannot connect to fax device 10.1.0.66/3217.
(2748) 09/06/23 09:38:32 - WARNING: DChannel::InitJobControl(): could not connect to job control.
(2540) 09/06/23 09:38:32 - INFO: OmcSock::Connect(): cannot connect socket.
(2540) 09/06/23 09:38:32 - ERROR: DChannel::Connect(): cannot connect to fax device 10.1.0.66/3218.
(2540) 09/06/23 09:38:32 - WARNING: DChannel::InitJobControl(): could not connect to job control.
(2748) 09/06/23 09:38:42 - INFO: DChannel::Connect(): connecting to fax device 10.1.0.66/3217.
(2540) 09/06/23 09:38:42 - INFO: DChannel::Connect(): connecting to fax device 10.1.0.66/3218.
(2540) 09/06/23 09:38:43 - INFO: OmcSock::Connect(): cannot connect socket.
(2540) 09/06/23 09:38:43 - ERROR: DChannel::Connect(): cannot connect to fax device 10.1.0.66/3218.
(2540) 09/06/23 09:38:43 - WARNING: DChannel::InitJobControl(): could not connect to job control.
(2748) 09/06/23 09:38:43 - INFO: OmcSock::Connect(): cannot connect socket.
(2748) 09/06/23 09:38:43 - ERROR: DChannel::Connect(): cannot connect to fax device 10.1.0.66/3217.
(2748) 09/06/23 09:38:43 - WARNING: DChannel::InitJobControl(): could not connect to job control.
Ich habe die Box und den Server bereits neu gestartet, leider ohne Erfolg.
Ich hoffe auf eine schnelle Lösung.....
mfg
Ralf
Update: ich habe die Lösung gefunden. Ein anderer Server im gleichen Netzwerksegment hatte ein Problem, also kein Problem vom Ferrari-Fax.
mfg
Ralf
