Nach Update Box nur Probleme
    Moin, habe der OMC Box upgedatet auf der neuste Version, danach war uns komplette VPN Netzwerk gestört, habe mittlerweile alles auf ein andere Gateway umgeleitet, und der Faxgateway (SMTP) is wieder erreichbar.
    Fax via Outlook ( Exchange in der Cloud) funktioniert soweit das wieder ein Job angelegt wird, diese wird aber nicht gefaxt.
    Ausschnit Logdatei:
    (1972) 11/11/01 00:11:01 - INFO: Incoming Status: Job status [0x0000a77b] (42875) will be processed...
    (1972) 11/11/01 00:11:01 - INFO: GetOriginatorData: Simon Bremer <simon.bremer@leder-brinkmann.de>[SMTP:simon.bremer@leder-brinkmann.de]
    (1972) 11/11/01 00:11:01 - INFO: ADsGetUserAttributeCache: Object 'CN=Simon Bremer,OU=Benutzer,DC...' cached successfully.
    (1972) 11/11/01 00:11:01 - ERROR: Check License: The user counter of the license group cannot be retrieved.
    (1972) 11/11/01 00:11:02 - INFO: CreateInternalErrorHTMLBodyText: There is no HTL Template.
    (1972) 11/11/01 00:11:03 - INFO: SendJobToMSX: (42875) Connection to 'mail.leder-brinkmann.de' established.
    (2992) 11/11/01 00:11:05 - INFO: MainThread: Passing default state cycle check.
    (2992) 11/11/01 00:11:05 - INFO: MainThread: Default state with one thread working. (5 cycles lifetime.)
    (2992) 11/11/01 00:11:05 - INFO: MainThread: Default state cycle reset passed.)
    (1972) 11/11/01 00:11:07 - ERROR: SendJobToMSX: (42875) Connection to 'vfmos100000002285.emea.microsoftonline.com' cannot be established. Command unrecognized
    (1972) 11/11/01 00:11:08 - ERROR: CreateErrorTextReport: Exchange Server post processing failed.
    (1972) 11/11/01 00:11:09 - ERROR: Incoming Document: SMTPRX Job [0x0000a77b] (42875) cannot be processed.
    (1972) 11/11/01 00:11:10 - ERROR: Incoming Document: The received job [0x0000a77b] (42875) could not be processed.
    (2992) 11/11/01 00:11:11 - INFO: MainThread: Passing default state cycle check.
    (2992) 11/11/01 00:11:11 - INFO: MainThread: Default state with one thread working. (5 cycles lifetime.)
    (2992) 11/11/01 00:11:11 - INFO: MainThread: Default state cycle reset passed.)
    (1972) 11/11/01 00:11:11 - WARNING: RequeueJob: The job [0x0000a77e] (42878) will be requeued for #33 time.
    (4972) 11/11/01 00:11:11 - INFO: OnJobSubmitReq(): Set thread credit '9'.
    (4972) 11/11/01 00:11:11 - INFO: Status message for job 42872 received.
    (4972) 11/11/01 00:11:11 - INFO: Incoming Status: Job status [0x0000a778] (42872) will be processed...
    (4972) 11/11/01 00:11:11 - INFO: GetOriginatorData: Simon Bremer <simon.bremer@leder-brinkmann.de>[SMTP:simon.bremer@leder-brinkmann.de]
    (4972) 11/11/01 00:11:11 - INFO: ADsGetUserAttributeCache: Object 'CN=Simon Bremer,OU=Benutzer,DC...' cached successfully.
    (4972) 11/11/01 00:11:11 - ERROR: Check License: The user counter of the license group cannot be retrieved.
    (4972) 11/11/01 00:11:12 - INFO: CreateInternalErrorHTMLBodyText: There is no HTL Template.
    (4972) 11/11/01 00:11:12 - INFO: SendJobToMSX: (42872) Connection to 'mail.leder-brinkmann.de' established.
    (2992) 11/11/01 00:11:16 - INFO: MainThread: Passing default state cycle check.
    (2992) 11/11/01 00:11:16 - INFO: MainThread: Default state with one thread working. (5 cycles lifetime.)
    (2992) 11/11/01 00:11:16 - INFO: MainThread: Default state cycle reset passed.)
    (4972) 11/11/01 00:11:17 - ERROR: SendJobToMSX: (42872) Connection to 'vfmos100000002285.emea.microsoftonline.com' cannot be established. Command unrecognized
    (4972) 11/11/01 00:11:18 - ERROR: CreateErrorTextReport: Exchange Server post processing failed.
    (4972) 11/11/01 00:11:19 - ERROR: Incoming Document: SMTPRX Job [0x0000a778] (42872) cannot be processed.
    (4972) 11/11/01 00:11:20 - ERROR: Incoming Document: The received job [0x0000a778] (42872) could not be processed.
    (4972) 11/11/01 00:11:21 - WARNING: RequeueJob: The job [0x0000a781] (42881) will be requeued for #30 time.
    (2992) 11/11/01 00:11:21 - INFO: MainThread: Passing default state cycle check.
    (2992) 11/11/01 00:11:21 - INFO: MainThread: Default state with no threads at work. (No cycle life.)
    (2992) 11/11/01 00:11:26 - INFO: MainThread: Passing default state cycle check.
    (2992) 11/11/01 00:11:26 - INFO: MainThread: Default state with no threads at work. (No cycle life.)
    smtp check:
    220
    ferrarifax SMTP
    HELO
    LEBRIMOBILE-PC
    250
    ferrarifax Hello business-178-015-002-254.static.arcor-ip.net, pleased to meet you
    220
    ferrarifax SMTP
    HELO
    LEBRIMOBILE-PC
    250
    QUIT
    221
    ferrarifax closing connection
    Officemaster auch noch mal auf der neuster version upgedatet
    Folgende Meldungen:
    (2992) 11/11/01 08:11:35 - INFO: MainThread: Default state with no threads at work. (No cycle life.)
    Closed on Tue Nov 01 08:11:37 2011
    Opened on Tue Nov 01 08:16:20 2011
    Library version 4.1.0.25331
    (3876) 11/11/01 08:16:20 - INFO: CreateDefCfg(): Creating a default configuration unit.
    (3876) 11/11/01 08:16:20 - INFO: License Check: Licensed version '4.0'.
    (3876) 11/11/01 08:16:20 - INFO: License Check: Maximum users: Fax: 25, SMS: 25, Voice: 25.
    (3876) 11/11/01 08:16:20 - INFO: RegisterAgent: Set 10 threads for job processing.
    (3876) 11/11/01 08:16:20 - ERROR: SMTP mode for Exchange Server 2010.
    (3876) 11/11/01 08:16:21 - INFO: Active Directory initialization succeeded.
    (5560) 11/11/01 08:16:21 - INFO: Component 'msxbcsgate0' (Version 4.0.0.9) main thread started.
    (5560) 11/11/01 08:16:21 - INFO: Build: Wed Sep 28 15:44:08 2011
    (5560) 11/11/01 08:16:21 - INFO: Start - Log Mode: Log Warnings, Errors and Information
    (5560) 11/11/01 08:16:22 - INFO: Start: The foam server is connectable on port 4196.
    (5560) 11/11/01 08:16:22 - INFO: Start: The messaging server collaboration was enabled.
    (5560) 11/11/01 08:16:22 - INFO: Start: The voice engine is now waiting for a call ...
    (5560) 11/11/01 08:16:27 - INFO: Metacache_GetUMCValue: Replicate dayly at 00:00h.
    (5560) 11/11/01 08:16:27 - ERROR: GetPostmaster: Postmaster is not set, please specify a postmaster!
    (5560) 11/11/01 08:16:28 - ERROR: GetPostmaster: This error can cause workflow interrupts!
    (5560) 11/11/01 08:16:29 - ERROR: GetPostmaster: Go to Exchange System Manager and specify a Postmaster for '(null)'!
    (5560) 11/11/01 08:17:50 - INFO: Metacache_ReplicateData(): Metacache replication request.
    (5560) 11/11/01 08:17:50 - INFO: Metacache_ReplicateData(): Replication done. (Metacache.mcss)
    (3876) 11/11/01 08:17:52 - INFO: RegisterAgent: Set 10 threads for job processing.
    Ich komme leider nicht weiter, vielleicht das Jemand hier helfen kann.
    MfG
    Simon Bremer
    Zuletzt geändert von leder brinkmann; 01.11.2011, 09:23.
