Submitting message status 11 and error code 13058
    Hallo OM's,
    habe folgende Probleme mit der Übersetztung der error code, wo finde ich welcher error code für was steht/bedeutet?
    Gibt es für die codes eine liste?
    (3308) 11/09/05 13:45:12 - INFO:    OnJobSubmitReq(): processing job  submit request for job 54630 and subcomponent 'capi 192.168.120.254 -  D00'.
    (3308) 11/09/05 13:45:12 - INFO:    JobQueue<AppSpec>::ActivateJobEntry(): processing job 54630 at 005F6C10.
    (3724) 11/09/05 13:45:12 - INFO:    DChannel::StartSend(): processing outgoing job 54630 on capi 192.168.120.254 - D00.
    (3724) 11/09/05 13:45:12 - INFO:    [phnumcor] MakePhoneNum(): automatic phone number correction not available for '3223041'.
    (3724) 11/09/05 13:45:12 - INFO:    --> :send --bchan_exec=fax.prc  --called_party_number="03223041"  --calling_party_number="03030021675"  --client_id=54630 --bchan_param=" --type=send  --tx-file='[192.168.120.254:1130]/OMCUMS-EXPORT-50946B2A/work/omcums0/send/0000d569.bff'  --bps=14400 --ecm=1 --resolution=200 --compression=MMR --header=1  --logo=1 --info-text='Zentrallabor Berlin' --csid='' --to-whom=''  --from-whom='' --pages=2  --debug-snfs=0 --debug-fc=0 --debug-t30=0  --debug-t4=0 --debug-lapi=0 --debug-modem=0 --stat-fd=1"
    (3308) 11/09/05 13:45:12 - INFO:    JobQueue<AppSpec>::SendJob(): job 00B05E78 submitted to channel 005F6CE0 at 005F6C10.
    (3724) 11/09/05 13:45:12 - INFO:    <-- :bchannel --message="start" --bchannel="1.a/B0/card/capi" --client_id="54630"
    (3724) 11/09/05 13:45:12 - INFO:    <-- :dchannel --message="offhook" --channel_id=0 --client_id="54630"
    (3724) 11/09/05 13:45:13 - INFO:    JobQueue<AppSpec>::AddChannel(): adding channel 005F6CE0 to list at 005F6C10.
    (3724) 11/09/05 13:45:15 - INFO:    <-- :alive
    (3724) 11/09/05 13:45:18 - INFO:    <-- :bchannel --message="finished" --bchannel="1.a/B0/card/capi" --client_id="54630"
    (3724) 11/09/05 13:45:18 - INFO:    <-- :dchannel --message="onhook"  --dchannel=0 --channel_id=0 --client_id="54630" --charges=0 --cause=0  --capi_reason=3302
    (3724) 11/09/05 13:45:18 - INFO:    Submitting message of type 'Send' to '3223041' with status 11 and error code 13058.
    Zuletzt geändert von swisslab; 07.09.2011, 14:28.
    Hallo Swisslab,
    die Fehlertexte sind Bestandteil der Rückmeldung an den User.
    Admins können diese aber auch in der Messaging Server Konfiguration unter "Extras > Systemeinstellungen > Fehlerverarbeitung > Fehlertexte" nachlesen.
    Status 11 ist z.B. ein CAPI-Fehler und 13058 bedeutet "Fehler in der ISDN-Schicht 2" - hier versteht sich also die verwendete CAPI-Karte nicht mit dem Anschluss...
    ...so als kleiner Hotline-Tipp ;-)
      Danke für den Tipp werde mal die Karte auswechseln, die ist nämlich schon ziemlich alt.
