Hallo zusammen, hatte das schon mal jemand? Eine Idee?
OMG Konfigurator ist 4.0.2.28646
Habe Firmwareupdate versucht. FW ist jeweils 4.0-150
kommt aber Fehler:
Initialisiere Updateprozedur
Checking prerequisites... Done.
Detecting hardware version... Done
Root drive is 'sda1'
OfficeMaster Gate
Shutting-down OfficeMaster services... Done
Preparing device for transfer... Done
Transferring firmware to device... Done
Installing new software version...
e echo "Start install packages: " $deblist | sed -e 's/\.\///g'; dpkg -i ${deblist}; rc=$?;if test $rc -eq 0; then omgrestart 2>/dev/null; echo "FLASH_READY"; else omgrestart 2>/dev/null; echo "FLASH_FAILED"; fi; sleep 4;fi; rm -rf ${TMPDIR} 2>/dev/null; rm -f /var/userfs.tar 2>/dev/null;
Install script found
Execute install script
Install Ubuntu Packages
Stopping watchdog
dpkg: error processing /var/ff_updateM1ehaf/ubuntu/omg-utilities_4.0-150_i386.deb (--install):
failed to open package info file `/var/lib/dpkg/tmp.ci/control' for reading: No such file or directory
Errors were encountered while processing:
rsyslog start/running, process 1822
FLASH_FAILED
Failed
The firmware update failed.
root@OMG200650:~#
Fehlgeschlagen
kommt aber Fehler:
OfficeMaster Gate
Stopping watchdog
FLASH_FAILED
Failed
root@OMG200650:~#
Fehlgeschlagen
