recS:
apS/iciS:
iciS:
colS:
Call Browser:
TAPI Connector:
Call Recording Configuration Center
Installer:
Configuration Tool:
Interactive Client:
New Features
Configuration Tool / recS:
recS:
Call Indicator:
TAPI Connector:
Call Browser:
recS:
- code optimizations in order to reduce CPU load
- more robust TCP reassembly for SIP over TCP recording
- bug fixes in SIP state machine
- improved call recording detection & separation in ATIS mode
- fix replay timing for demo devices
apS/iciS:
- fixed crash, when recording in timeslot mode
iciS:
- fixed memory leak
colS:
- fixed potential socket leak in rare error conditions
- fixed unstoppable collector service, if collector is running under maximum load
Call Browser:
- be more robust against defective call records
- fixed B channel numbering on non-PRI devices
- fixed crash when starting the Call Browser on WinXP
- fixed broken PDF view of no-ECM FAX recordings
- fixed problem deleting main password
- fixed problem changing a phonebook entry
TAPI Connector:
- ignore non-numeric characters in calling/called IDs reported by TAPI before applying the IDs in call matching
- fixed flickering device tree
Installer:
- fixed crash when running on WinXP
- do not install new software, if previous version could not uninstalled
Configuration Tool:
- strip off any leading or trailing spaces in TAPI call matching outbound
- dial prefix setting
Interactive Client:
- fixed some sporadic crashes
- fixed broken audio playback
New Features
- new license management supporting online license activation and extending of licensed recording channels
- added an option to select whether to use the preferred identity or the From field of SIP messages as source for the recorded caller ID
- allow a SIP over TCP configuration without specifying the SIP server
- support for SIP server name resolution using NAPTR/SRV records
recS:
- increased maximum number of attached line state API clients to 256
- print log message on detection of one or no way audio in SIP recordings
Call Indicator:
- complete new implementation of Call Indicator now supporting labeled groups and a work load view
TAPI Connector:
- added support for tracking of parked calls
Call Browser:
- added support for drag&drop of recordings out of the Call Browser
