Firmware 4.0.360 and 4.1.360
FEATURE
FEATURE 4.1 only
BUGFIX
BUGFIX 4.1 only
FEATURE
- New profiles
- Swisscom profiles (G.711, T.38) added
- SIP2Lync enhancement
- Inform SIP2Lync after REFER to set DECT phone available
- ignore case of udptl in sdp
- Handle user to user messages in early media to support DTMF in early media on SBC
- Always send anonymous@anonymous.invalid instead of configured domain in From header
FEATURE 4.1 only
- Failover in DNS if preferred partner is not reachable
- Find new preferred partner on register
- support for "refused" messages
BUGFIX
- SMS: Festnetz SMS over PCM loopack fixed
- WebUI: Backed up licenses are shown as expired
- Fax: handle CRP after TCF and carrier lost after TCF --> resend DCS/TCF
- error in number check on registered call routing
- free preferred address before register again
- fix for partner channel count check on PCM interfaces
- fix echo canceler memory leak
- Add "Privacy: id" header for anonymous calls
- Fix phone number handling – problem was introduced in version 4.0-330 on Ubuntu platforms
- Fix memory leaks and misuse in callp2
- don't resolve contact on incoming call if via is available
- traceback on routing call for registered devices fixed
BUGFIX 4.1 only
- make sure responses are always sent to same IP
- Remove file handle leak
- fix for Refer traceback on outgoing call
