- check ip in routing also on ICT (interconnect)
- CISCO MWI support
- send ACK with retry OK CSEQ (NFON)
- parse only first history-info
- transparent FACILITY based call deflection handling for drop and insert scenarios; set --FacilityTransparency for isdn process to enable
- do not stop playing ringtones if packets arrive that cannot be decrypted or have to be ignored
- start interconnect process on overlapped dialing in PlugAndInsert Scenario to provide Dialtone to devices
- cseq fix in T.38 reinvite
- record route order in T.38 reinvite fix
- add omgsetdisableds0tontmode script to Set diabled S0 to NT mode
- changed regex to correctly detect default gateway
- decreased CPU usage of producers
- speed ups:
- EchoCanceller
- ISDN process
- Fixed stability issue of producers that resulted in unusable webui
- Better T.38 fax timing
- CentOS 6.8 Support for OfficeMasterGate Advanced and Virtual Edition
- Optimized register-handling of SIP2Lync
- Handle out of band DTMF for voice connections
Firmware 4.0.310 (22.11.2016)
Chris HelbingStichworte: -
