Firmware 4.0.250 (2015-09-03)
    Health Page (new Web UI)
    • New design enabled by default
    • Old UI is reachable on port 8080
    • Default can be changed
    • Support https
    • Detailed license information
    • Display elapsed time of active calls
    Fax (T.30/T.38)
    • Send calling tone in T.38 mode (to reach multifunction devices with fax detection)
    • Resend DIS on CRP ("command repeat" - optional T.30 command)
    • Accept TCF (training check) without T4-non-ecm-sig-end (tolerate Misbehavior of Unify/HiPath)
    • Cisco T.38 gateway: optimize T.38 transmit timing
    • Optimizations in handling some T.38 details
    • CED Signalling via T.38
    • When waiting for TCF do not interpret no-signal as TCF error if not yet in high speed mode
    • Increase TCF timeout in T.30/T.38 (especially for HiPath)
    • After PPR in T.38 mode we did not always switch to high-speed mode
    • Handle t38 session reinvite for session refresh
    • Send T.38 V.21 data in single byte blocks for better compatibility with Colt Trunk/Sonus SBC
    • Several corrections in T.38 fax gateway
    SIP
    • Generate ringback tone until packets arriving from rtp
    • Ignore messages < 8 bytes on udp
    • SIP parsing: Ignore spurious TLS header signaled to SIP stack which caused misinterpretaion of next SIP message.
    • Grandstream ATA:
      • REFER with Replaces header fixed
      • Error with call transfers fixed
    • No ringback tone if SDP in 180 ringing is available but no data coming via RTP
    • No ringback tone if external call from to Lync was forwarded to other Lync user
    • Support VIA change in UPDATE
    • CallingName superseeds diversionName
    • Clear record route on reinvite (T.38 with Avaya)
    • Error assembling TCP segmented messages
    • Early Media
      • Fix for no early media stream if there is a progress in REFER
      • Decryption failure on multiple early media streams
    • a=sendrecv didn't work after a=inactive
    ISDN
    • Log level changes are activated without restart
    • Crash on unregister ISDN connection
    • Call proceeding added for simulation in ISDN to ISDN
    • Support for RESTART "storm" - If PBX sends many RESTARTS with channel info not all of them have been acknowledged.
    • Changing log levels (Layer 1-4) might crash ISDN process
    • IRQ handling changed to avoid "unhandled IRQs" message
    Other areas
    • Optimizations for OfficeMaster Gate Advanced R2 including new FPGA version
    • New Echo Canceler - better cancellation with less CPU overhead!
    • New OMG boot theme
    • Licensing: by default only E1 is allowed on PRI, T1 can be enabled separately
    • Call deflection support in drop & insert scenarios
    • Support for INVITE with REPLACES header from Alcatel OmniPCX Enterprise
    • Firewall (IPTables): Allow https (443)
    • Higher amplitude in V.21 modem mode
    • Info about packet loss or reordered packets
    • Routing behavior:
      • Crash if nothing matches for SIP to ISDN routing
      • Failover Routing didn't try second server on 503
      • Also check number match on blocked rules if IP address is given
    • SMS via PSTN: Decode UC-2 (16 bit) characters (occurs when emoticons are used)
    Zuletzt geändert von Chris Helbing; 03.09.2015, 15:35.
