PowerShell Cmdlets 2.0.3.2
OfficeMaster Gate Configuration 4.3.0.925
Firmware 4.0.200
SECURITY
- Firmware 4.0.200 contains functional enhancements, some bug fixes and improved overall stability
- Preview of new enhanced Web UI available at port 8080 (can be made default)
- First release of OfficeMaster PowerShell Cmdlets
- Sample monitoring script available
- first public availability
- can be found in download area on our web site (in hardware section)
- sample script for monitoring will be available in forum
- minor UI enhancements (grey options where not applicable )
- if regular expression starts with '+', add '\' automatically to avoid common user error
- ISDN clock settings if more than 4 PRI installed
- simplified move from trial to full license
Firmware 4.0.200
SECURITY
- bash and openssl patch
- TRACK/TRACE-feature deactivated in apache
- handle Lync header to avoid missed call notification for AASTRA DECT Phones (Reason 200 header)
- new debug keyword "REGISTER:" to filter register related stuff
- sms.prc: default DCS (data coding scheme) is 0x00 now (was 0xF1); --dcs= parameter added; get rid of warnings
- all recovery and installation images moved to CentOS 6.6 base
- new web interface on port 8080 (CentOS only)
- changed error message in centos-tar if installed on Ubuntu
- consistent Hyper-V adapter order
- Hyper-V guest demons in new recovery images
- forward high layer compatibility information element telephony in drop and insert
- SIP MWI parameter for FROM header at and of string /nnn On-String: 10.1.2.3:5060/udp/9999
- block destination on any 5xx response for options not only on 503
- omgfilesysteminfo added, files systems can be checked via PowerShell
- config.struct_Box.bool_IgnoreFirstT38Reinvite=true to ignore first T38 reinvite from Cisco CUCM
- suppress calling name on demand config.struct_Box.bool_IgnoreCallingPartyName=true
- handle config.struct_Box.string_IsdnCipValue also on ISDN to ISDN calls
- facility decode HiPath Redirecting Number International
- new ServerView Packages, disabled ServerView on all but RX1330M1
- support for register fetch binding for Auerswald
- ignore "jaK" message from linphone
- do not change L2 state if RR timer recovery active to avoid spurious L2 down indication
- add 60 extra seconds before unregistering a device which could be unregistered too early
- transparent UTF-8 transport for caller name if PCM (SIP2SIP) interface is used
- handle progress indicator in SETUP_ACK
- on sndonly keep sending music on hold until packets arrive to enable MoH with Polycom VVX
- preserve TON (type of number) in ISDN2ISDN overlapped dialing scenario
- do not hang up on Layer 3 STATUS with invalid info element
- support old MWI syntax for sip without FROM header information
- handle T38 reinvite from Alcatel OXE (session timer)
- support inbound fax with Exchange UM via SIP2SIP
- do not send data with len = 0 in fax T.38 gateway
- handle new stream and encryption if a new stream sent witch acceptAnyStream set (to avoid one-way audio)
- DTMF signaled more than once if multiple DTMF packets with marker "on" received
- send ACK to CONTACT from OK not to INVITE URI (get old behavior by config.struct_Box.bool_UseContactFromOk=true)
- copy OPAQUE in authorize in all modes (REGISTER)
- VIA branch has to be changed for in ACK for OK
- wrong handling on non match of numberlist in SIP initiated routes
- support of country setting for analog port on OfficeMaster Gate Advanced
- faxt38.prc data rate was too slow in non ECM mode
- clock not set due to misspelled NTPSERVER variable in checkntp script
- do not send MoH on Progress
- handle nil pointer on reinvite for T38
- CentOS only supports 2 DNS servers in config
- missing contact header in register crashes mux_sip.lua
- send cca_resp if process is unknown in mux_isdn to avoid losing call resource
