Firmware 4.0.150 / OfficeMaster Gate Configuration / Syslog Service
    Firmware 4.0.150 contains functional enhancements, some bug fixes and improved overall stability
    Web UI support for time-limited combined recording of syslog and pcap trace
    • "Syslog Analyzer” keeps history of all search expressions to support jumping around during log file analysis
    • Support of draining mode – deny new call attempts to prepare for downtime (e.g. to update firmware) without interrupting active calls
    • Optional variable priority for all physical and virtual interfaces; support of controlled trunk overflow
    • ISDN Layer 1 CRC4 settings now directly available in GUI
    • Enhanced backup features including full backup (configuration, certificates, licenses) and keeping configuration history (default: last 100 changes)
    • Interfaces can now get individual names and descriptions to document individual configuration
    • “Power off” menu option for controlled shutdown of gateways (not for all hardware types)
    Syslog Service
    • New Syslog service with larger buffers to avoid data loss when using Syslog via UDP (which is recommended to avoid TCP backlog)
    Firmware 4.0.150
    • Dynamic activation of more configuration changes (e.g. ISDN logging settings)
    • Support for QSIG call deflection
    • Call rerouting support for Alcatel OmniPCX Enterprise Release 10.x
    • Support for delayed Call Deflection
    • New parameters to configure optional T.38 settings (e.g. redundancy)
    • Accept any stream after early media is now standard. Use -F to switch change back to to old behavior.
    • TOS (DSCP) support in Voice Mail together with OfficeMaster Suite
    • Draining calls to prepare for maintenance
    • New self-test with details
    • Configure CRC4 setting in GUI
    • Cleanup Channels after 2 days (default value)
    • ISDN failover on error is now disabled by default
    • Facility based MWI
    • Prioritize diversion header before history-info header as rerouting info
    • ATA analog modem selects Audio 3.1 kHz bearer capability
    • Support G.711 Fax with new QSC trunk (SIPconnect 1.1)
    • SIP MWI notify support
    • Support Fujitsu RX200 S8
    • In seldom situations gateway stopped IP communications and needed reboot
    • RTP process could stop and write core dumps
    • Segmented ISDN SETUP messages could cause stop/restart of ISDN process
    • DTMF support via SIP2Lync on calls between two SIP or DECT devices fixed
    • Fix for one way audio if encrypted and REFER and RTP from old partner arriving before RTP from new partner (especially with Polycom VVX devices)
    • Missing MOH if Loop device and noAnalogHandling was set
    • I - "info" in console menu showed old address after setting temporary network address
    • LUA error if no OfficeMaster Suite connected and multiple destinations configured
    • Sending OPTIONS ping could cause resource problems after long time
    • Wrong SIP message splitting if 2 messages came in a single TCP segment
    • Parse correct port from short T.38 SDP
    • Fixed parsing from URI like “sip:1.2.3.4;transport=tcp”
    • Sipgate needs old URI in Cancel; contact URI for all others
    • Exchange UM: BYE was sent to wrong port
