Firmware 4.0.100
    Firmware 4.0.100
    EN
    INFO
    • Default DTMF level was too low, now set to 9 dBm0, used by Siemens PBX
    • QSC SIP-Trunk Certification; IPfonie ® extended connect with register
    • Support of Fujitsu RX 100/200 S8
    FEATURE
    • Better support for external SIP trunks, don't add IP Address if @xxx.yy is already included in replacement (works per routing rule)
    • Extended signaling for SIP2Lync to avoid one-way audio with mixed endpoint types
    • Faster establishing of new calls
    • Optimization for T.38 fax connections via Alcatel OmniPCX
    • Changed default coding in Layer 3 for BRI when QSIG is activated
    • CED and CNG detection can now be activated via a new parameter
    • T.38 with OfficeMaster – no configuration at OfficeMaster Suite needed, everything handled in gateway rules
    • T.38 parameter sets to activate different T.38 reINVITE behavior: --t38 --t38p --t38rp --t38sp
    • DTMF generation via SIP INFO added
    • Segmented messages in ISDN Layer 3 now supported
    • Dial PBX extensions via DTMF
    • Cost based Routing between ports (needs Beta Release of OfficeMaster Gate Configuration)
    BUGFIX
    • Problems starting a T.38 fax call with last release, fixed
    • Accept DTMF packets also for partner detection
    • Accept compact header for call-id and contact
    • Error while connecting to Sipgate trunks corrected
    • Better timing on early reuse of layer 4 index, resource lost problem fixed
    • TCP handling more robust now under heavy load
    • MoH only in one direction with last release, fixed
    • “Info” in OMGMENU (Console) shows old IP settings after configuring temporary network address
    • Clear B-Channel States on restart to show correct count of active calls
    • Correct call transfer handling with Polycom VVX devices for calls initiated by Polycom device
    • Using a numberlist on blocking rules caused script error
    • Destination number on incoming Invite now taken from request line, can be switched back to using “To”-Header via configuration tool
    DE
    INFO
    • Standard DTMF Pegel wurde auf -9 dBm0 erhöht, relevant für u.a. Siemens TKs, die diesen Wert auch berücksichtigen
    • QSC SIP-Trunk Zertifizierung; IPfonie ® extended connect mit Registrierung
    FEATURE
    • Externe SIP-Trunks benötigen teils nicht die IP-Adresse hinter der Rufnummer, dies kann je Regel durch Hinzufügen von "@TEXT" korrigiert werden.
    • Anpassungen bei der Auswertung der SIP-Headerinformationen für neue SIP2Lync Version – vermeidet one-way Audio bei gemischten Endgerätetypen durch Auswahl des jeweils passenden SDP-Abschnitts
    • Schnellerer Verbindungsaufbau durch diverse Optimierungen
    • Optimierungen für T.38 Fax über Alcatel OmniPCX
    • Default Layer 3 Kodierungen für S0 geändert bei aktiviertem QSIG Protokoll
    • Faxtonerkennung wird nun über Parameter aktiviert
    • T.38 Fax über OfficeMaster wird nun komplett in den Gateway-Regeln konfiguriert; reINVITE Verhalten beliebig einstellbar: --t38 --t38p --t38rp --t38sp
    • DTMF Töne, die über SIP INFO empfangen wurden werden nun am ISDN Port abgespielt
    • Segmentierte Nachrichten in ISDN Schicht 3 werden jetzt unterstützt
    • Kostenbasiertes Routing auf Portebene möglich (erfordert Beta Release der OM Gate Configuration)
    ERROR
    • Manche Compact Header wurden bisher nicht korrekt akzeptiert, dies wurde behoben
    • Fehler im Verbindungsaufbau mit T.38 behoben
    • Aufbau des RTP-Streams benötigt ein initiales Signal auf dem Kanal, DTMF hat dies bisher nicht freigeschaltet, dies wurde behoben
    • Fehler bei der Anbindung an Sipgate behoben
    • Der Abstand zur erneuten Verwendung eines Kanals wurde korrigiert
    • Bei großer Last sind vereinzelt TCP Connections gestoppt worden, dies wurde korrigiert
    • Im Release 90 wird MoH (music on hold) nur bei einer Anrufrichtung abgespielt, dies wurde korrigiert
    • “Info” im OMGMENU (Console) hat nach setzen einer temporären IP-Adresse immer noch die alte Einstellung angezeigt
    • B-Channel Status löschen bei Restart, damit die Belegungsanzeige korrekt funktioniert
    • Call Transfer mit Polycom VVX bei Gesprächen, die vom Polycom initiiert wurden, geht jetzt wieder
    • Blockierungsregeln mit Nutzung einer Nummernliste funktionieren jetzt
    • Die Zielnummer im ankommenden Invite wird jetzt stanardmäßig von der Rquest-Zeile übernommen, das bisherige Verhalten (aus dem “TO“-Header) kann in den VoIP Parametern aktiviert werden
    Zuletzt geändert von Chris Helbing; 14.05.2014, 10:54. Grund: S8 ergänzt
    Chris Helbing
