EN
DE
ERROR
- Default DTMF level was too low, now set to 9 dBm0, used by Siemens PBX
- QSC SIP-Trunk Certification; IPfonie ® extended connect with register
- Support of Fujitsu RX 100/200 S8
- Better support for external SIP trunks, don't add IP Address if @xxx.yy is already included in replacement (works per routing rule)
- Extended signaling for SIP2Lync to avoid one-way audio with mixed endpoint types
- Faster establishing of new calls
- Optimization for T.38 fax connections via Alcatel OmniPCX
- Changed default coding in Layer 3 for BRI when QSIG is activated
- CED and CNG detection can now be activated via a new parameter
- T.38 with OfficeMaster – no configuration at OfficeMaster Suite needed, everything handled in gateway rules
- T.38 parameter sets to activate different T.38 reINVITE behavior: --t38 --t38p --t38rp --t38sp
- DTMF generation via SIP INFO added
- Segmented messages in ISDN Layer 3 now supported
- Dial PBX extensions via DTMF
- Cost based Routing between ports (needs Beta Release of OfficeMaster Gate Configuration)
- Problems starting a T.38 fax call with last release, fixed
- Accept DTMF packets also for partner detection
- Accept compact header for call-id and contact
- Error while connecting to Sipgate trunks corrected
- Better timing on early reuse of layer 4 index, resource lost problem fixed
- TCP handling more robust now under heavy load
- MoH only in one direction with last release, fixed
- “Info” in OMGMENU (Console) shows old IP settings after configuring temporary network address
- Clear B-Channel States on restart to show correct count of active calls
- Correct call transfer handling with Polycom VVX devices for calls initiated by Polycom device
- Using a numberlist on blocking rules caused script error
- Destination number on incoming Invite now taken from request line, can be switched back to using “To”-Header via configuration tool
DE
- Standard DTMF Pegel wurde auf -9 dBm0 erhöht, relevant für u.a. Siemens TKs, die diesen Wert auch berücksichtigen
- QSC SIP-Trunk Zertifizierung; IPfonie ® extended connect mit Registrierung
- Externe SIP-Trunks benötigen teils nicht die IP-Adresse hinter der Rufnummer, dies kann je Regel durch Hinzufügen von "@TEXT" korrigiert werden.
- Anpassungen bei der Auswertung der SIP-Headerinformationen für neue SIP2Lync Version – vermeidet one-way Audio bei gemischten Endgerätetypen durch Auswahl des jeweils passenden SDP-Abschnitts
- Schnellerer Verbindungsaufbau durch diverse Optimierungen
- Optimierungen für T.38 Fax über Alcatel OmniPCX
- Default Layer 3 Kodierungen für S0 geändert bei aktiviertem QSIG Protokoll
- Faxtonerkennung wird nun über Parameter aktiviert
- T.38 Fax über OfficeMaster wird nun komplett in den Gateway-Regeln konfiguriert; reINVITE Verhalten beliebig einstellbar: --t38 --t38p --t38rp --t38sp
- DTMF Töne, die über SIP INFO empfangen wurden werden nun am ISDN Port abgespielt
- Segmentierte Nachrichten in ISDN Schicht 3 werden jetzt unterstützt
- Kostenbasiertes Routing auf Portebene möglich (erfordert Beta Release der OM Gate Configuration)
ERROR
- Manche Compact Header wurden bisher nicht korrekt akzeptiert, dies wurde behoben
- Fehler im Verbindungsaufbau mit T.38 behoben
- Aufbau des RTP-Streams benötigt ein initiales Signal auf dem Kanal, DTMF hat dies bisher nicht freigeschaltet, dies wurde behoben
- Fehler bei der Anbindung an Sipgate behoben
- Der Abstand zur erneuten Verwendung eines Kanals wurde korrigiert
- Bei großer Last sind vereinzelt TCP Connections gestoppt worden, dies wurde korrigiert
- Im Release 90 wird MoH (music on hold) nur bei einer Anrufrichtung abgespielt, dies wurde korrigiert
- “Info” im OMGMENU (Console) hat nach setzen einer temporären IP-Adresse immer noch die alte Einstellung angezeigt
- B-Channel Status löschen bei Restart, damit die Belegungsanzeige korrekt funktioniert
- Call Transfer mit Polycom VVX bei Gesprächen, die vom Polycom initiiert wurden, geht jetzt wieder
- Blockierungsregeln mit Nutzung einer Nummernliste funktionieren jetzt
- Die Zielnummer im ankommenden Invite wird jetzt stanardmäßig von der Rquest-Zeile übernommen, das bisherige Verhalten (aus dem “TO“-Header) kann in den VoIP Parametern aktiviert werden
