Firmware 4.0.60
    Firmware 4.0.60
    • New supported SIP trunks:
      • support for Winitu SIP trunk
      • support for Avaya SIP trunk
    • Additionally there is a new OfficeMaster Gate Configuration online.
    FEATURES
    • add History-Info as known name
    • add options
      • --CallingPartyNumberOrderUserProvidedFirst=1;
      • --CallingPartyNumberOrderNetworkProvidedFirst=0;
      • --CallingPartyNumberOrderAsIs=0;
      • --saveWaveFile; (parameter for RTP or to be used in call processing rules) saves call as stereo wave file
    • option to disable firewall in omgmenu
    • anonymous calls now contain domain instead of “anonymous.invalid”
    • session timer support
    • support for multibodypart/mixed SDPs in INVITE (AVAYA/CS1000 SIP)
    • use Request URI for destination instead of TO-header
      set CONFIG:config.struct_Box.bool_useToForRouting=true to still use TO-header
    BUGFIXES
    • long RELEASE fixed/ghost facilities on hang up fixed
    • if cause->recommendation==DSS1_CAUSE_RECOMMENDATION_Q931 send 2 byte cause (Q931 is default)
    • be more kind to devices changing SSRC to prevent one way audio
      fix one way audio with Grandstream ATA (Grandstream changes SSRC after ACK)
    • wrong ICMP type changed to allow ping if firewall is enabled
    • wrong clockprio on 4PRI if manual setting is used
    • stop syslog in WebUI did not stop recording
    • one way audio with TLS and forwarded calls
    • directly forwarded calls from response groups caused decryption problem
