Firmware 4.0.20 (2013-06-03) - EN
    Firmware 4.0.20 focusses on SIP-Trunk support and SBC Features including configuration of second LAN adapter (if available), different subnets and flexible firewall profiles.
    S2M/PRI Hardware (Art.:20604, 20614, 22114, 22124) and OfficeMaster Gate SBA (Art.: 22314) are now based on Fujitsu Servers.
    Firmware
    FEATURE:
    • Support of several SIP-Trunks through predefined parameter sets which can be selected in OfficeMaster Gate Config – more will be added
      Supported SIP-Trunks
    • New parameter to force fax communication via G.711 pass-through on SIP-Trunks
      Outbound:
      CONFIG:config.struct_Box.string_FaxOutboundmode = "G711":
      Inbound:
      CONFIG:config.struct_Box.string_FaxInboundMode == "G711"
    • For a better device compatibility analog calls from FXS-Board are now signaled with Audio 3,1 kHz bearer capability (instead of speech)
      ISDN, Q.931, Bearer Capability = 3,1 kHz audio
    • SIP-Proxy Support for SIP-Trunks
    • Support for more than one connected OfficeMaster Messaging Server – Load balancing and failover configurations are possible
    • Redirected number now also decoded from Q.SIG facility (Remote Operations Protocol)
      Firewall and Routing
      SBC and administrative connections can now be limited to an IP-Address or range and it is possible to add manual routing. The following optional Firewall settings are supported separately for both LAN interfaces:
    • Administration interface, e.g OfficeMaster Gate Config
    • Messaging Server connections
    • WebUI access
    • SIP (UDP) connections
    • SIP (TCP) connections
    • SIP (TLS) connections
    • Manual Route to a dedicated host or to a network
    • Routing support for more than one network interface and IP-Address
    WebUI
    FEATURE:
    • Confirmation before administrative killing active call via WebUI
    • System Traces -> Capture (Network Dump) for different network interfaces
    • Colorized ISDN connection states
    • Up to 1000 lines in live Syslog
    BUGFIX:
    • Active Calls overlay
    • Ping a DNS CNAME record
    Zuletzt geändert von Dirk Krüger; 03.06.2013, 14:20.
    Dirk Krüger
    Product Manager / Unified Communications
