EN - first part
DE - Zweiter Teil
--------------------EN----------------------
Before updating from an earlier version please reboot the gateway and then start update.
WebUI
FEATURES
Syslog
FEATURES
Adding a new Tracing function.
Example:
Firmware
FEATURES
--------------------DE----------------------
Vor dem Update auf diese Version bitte das Gateway einmal neu starten.
WebUI
FEATURES
Syslog
FEATURES
Neue Schlüsselwörter/Schlagwörter zur einfachen Analyse der Logfiles
Example:
Firmware
FEATURES
DE - Zweiter Teil
WebUI
FEATURES
- System Traces Tab shows more information (last outbound call, Q.931 decoding)
- Start Syslog on WebUI is independent from configured Sylog Service
- Download link for Ferrari-electronic SNMP-MIB (OID 1.3.6.1.4.1.17524)
- Monitor Active Calls in Linestatus; Calls can be terminated
Syslog
FEATURES
- “CM: Channeldump <DATE>” Every hour all active calls are shown with Task-ID and start date/time
Example:
OPR0100034 mux_isdn:0 (1) CM: CHANNELDUMP Mon Oct 29 10:13:39 2012 OPR0100034 mux_isdn:0 (1) CM: CHANNELDUMP ISDN1 Mon Oct 29 10:07:06 2012 bChannel1 task=isdn_isdn:2008 cpn=+493328455949 cgn1=+49xxxxx cgn2= crn= OPR0100034 mux_isdn:0 (1) CM: CHANNELDUMP ISDN1 Mon Oct 29 10:10:01 2012 bChannel1 task=isdn_isdn:2006 cpn=+493328455948 cgn1=+49xxxxx cgn2= crn=
- Logging Interval is adjustable by configuring logging parameter "export CHANNELDUMP=<30000>" sets interval to 30sec
Firmware
FEATURES
- New ISDN Parameter to disable CRC4 Check (FPGA images up to 0104 ignore CRC4 but may have sync problems on some networks, 0105 requires correct CRC4 but this can be disabled)
- Optimized resource usage, faster ISDN to ISDN interconnect.
- Automatic D-Channel Failover for outbound routing
- Many small improvements
- SIP / UDP - Port closed after receiving erroneous Packets
- Fixed Memory leak in ISDN to ISDN process (Drop and Insert) / Impact: One-way Audio and resource lost in some high load scenarios.
- SIP to ISDN failover fixes
- Set default DTMF length to 100ms instead of 280ms
- IPv4/IPv6 Hybrid Scenario / Preferred protocol version can be configured, default is IPv4.
- Jobcontrol with OfficeMaster Messaging Server handles more than 9 D-Channels
WebUI
FEATURES
- Last ISDN outbound calls Tab, loggt jetzt auch Q.931 Informationen (Tracing)
- Start Syslog ist unabhängig vom konfigurierten Syslog Service
- Download Link für Ferrari-electronic SNMP-MIB (OID 1.3.6.1.4.1.17524)
- Überarbeitete Darstellung von „Active Calls“ unter Linestatus; Calls können beendet werden
Syslog
FEATURES
- “CM: Channeldump <DATE>” Schreibt stündlich eine Liste aller aktiven Rufe mit Task-ID.
Example:
- Das Intervall kann mit dem Log Parameter angepasst werden Bsp.:"export CHANNELDUMP=<30000>" setzt den Intervall auf 30sek
Firmware
FEATURES
- ISDN Parameter zum Abschalten von CRC4 Prüfungen (bis FPGA Version 0104 wird CRC4 nicht geprüft, ab Version 0105 muss CRC4 korrekt sein, diese Prüfung kann aber abgeschaltet werden)
- Schnellerer Verbindungsaufbau von ISDN zu ISDN Verbindungen (Drop and Insert)
- Automatischer ISDN-Failover über mehrere D-Kanäle
- SIP / UDP - Port hat sich bei Netzwerkfehlern geschlossen
- Ressourcenfehler bei ISDN zu ISDN (Drop and Insert) / Auswirkung: One-way Audio und Kanalverlust bei sehr hoher Kanallast.
- SIP zu ISDN Failover Korrekturen
- DTMF Standard Tonlänge von 280ms auf 100ms verändert
- IPv4/IPv6 Hybrid Szenario / Bevorzugtes Protokoll ist jetzt einstellbar. In der Standardeinstellung wird IPv4 bevorzugt.
- Jobcontrol mit OfficeMaster Messaging Server. Gateway kann nun im Messaging Server Modus mehr als 9 D-Kanäle adressieren.
