New Features
recS
Call Browser
apS
recS
fax2pdf
Call Recording Configuration Center
					recS
- improved phone number extraction algorithm for SIP addresses (can be enabled in SIP device configuration)
Call Browser
- fixed a crash, when opening a paused recording as PDF
 - fixed crash, when closing the application while the column configuration dialog is open
apS
- move recordings with an invalid fingerprint into the error folder instead processing it further, which may lead to non-recoverable damaged recordings
recS
- fixed non-working TAPI call matching at the end of a call
fax2pdf
- fixed problem decoding FAX transmission with an unusually high signal echo
 - proper handling of Ferrari electronic NSF
 - be more robust on incomplete FAX transmissions
- fixed problem loading network configuration, if the NTP server list on device is empty
