New Features
fax2pdf:
fax2pdf:
fax2pdf:
- emit PDF/A compliant PDF files
- improved logging of collector service
- improved logging of database rebuild
fax2pdf:
- fixed problem opening PDF file in Acrobat Reader DC, if the fax had T.4 decoding errors
- fixed rare problem in SIP address parser leading to weird display names
- fixed wrong sample count in SIP recordings
- fix for missing fingerprint information after re-indexing the database
- fixed "File not found" problem after upgrading the software from 4.8.0-x to a later version
- Note that the fixed bug led to invalid WAV file names. After installing the new software version the all affected WAV files will be automatically renamed in background. Depending on the database size this process may take several minutes. New recordings arriving during that time will be delayed (i.e. they will not appear in the Call Browser) until the file names are corrected.
- fixed race condition when restarting services on OMG devices leading to corrupted recordings
- avoid multiple instances of the same service running on one machine
