Firmware 4.0.299 (Testversion)
    • check ip in routing also on ICT (interconnect)
    • CISCO MWI support
    • send ACK with retry OK CSEQ (NFON)
    • parse only first history-info
    • transparent FACILITY based call deflection handling for drop and insert scenarios; set --FacilityTransparency for isdn process to enable
    • do not stop playing ringtones if packets arrive that cannot be decrypted or have to be ignored
    • start interconnect process on overlapped dialing in PlugAndInsert Scenario to provide Dialtone to devices
    • cseq fix in T.38 reinvite
    • record route order in T.38 reinvite fix
    • add omgsetdisableds0tontmode script to Set diabled S0 to NT mode
    • changed regex to correctly detect default gateway
    • decreased CPU usage of producers
    • speed ups:
      • EchoCanceller
      • ISDN process
    • Fixed stability issue of producers that resulted in unusable webui
    Release Plan for Firmware 4.0.310 (22.11.2016)
    • CISCO MWI support
    • speed ups:
      • EchoCanceller
      • ISDN process
    • Better T.38 fax timing
    • CentOS 6.8 Support for OfficeMasterGate Advanced and Virtual Edition
    • Optimized register-handling of SIP2Lync
    • Handle out of band DTMF for voice connections
    Zuletzt geändert von Chris Helbing; 18.11.2016, 12:41.
