BUGFIX
recS:
  • code optimizations in order to reduce CPU load
  • more robust TCP reassembly for SIP over TCP recording
  • bug fixes in SIP state machine
  • improved call recording detection & separation in ATIS mode
  • fix replay timing for demo devices
apS/iciS:
  • fixed crash, when recording in timeslot mode
iciS:
  • fixed memory leak
colS:
  • fixed potential socket leak in rare error conditions
  • fixed unstoppable collector service, if collector is running under maximum load
Call Browser:
  • be more robust against defective call records
  • fixed B channel numbering on non-PRI devices
  • fixed crash when starting the Call Browser on WinXP
  • fixed broken PDF view of no-ECM FAX recordings
  • fixed problem deleting main password
  • fixed problem changing a phonebook entry
TAPI Connector:
  • ignore non-numeric characters in calling/called IDs reported by TAPI before applying the IDs in call matching
Call Recording Configuration Center
  • fixed flickering device tree
Installer:
  • fixed crash when running on WinXP
  • do not install new software, if previous version could not uninstalled
Configuration Tool:
  • strip off any leading or trailing spaces in TAPI call matching outbound
  • dial prefix setting
Interactive Client:
  • fixed some sporadic crashes
  • fixed broken audio playback
New Features
Configuration Tool / recS:
  • new license management supporting online license activation and extending of licensed recording channels
  • added an option to select whether to use the preferred identity or the From field of SIP messages as source for the recorded caller ID
  • allow a SIP over TCP configuration without specifying the SIP server
  • support for SIP server name resolution using NAPTR/SRV records
recS:
  • increased maximum number of attached line state API clients to 256
  • print log message on detection of one or no way audio in SIP recordings
Call Indicator:
  • complete new implementation of Call Indicator now supporting labeled groups and a work load view
TAPI Connector:
  • added support for tracking of parked calls
Call Browser:
  • added support for drag&drop of recordings out of the Call Browser
